Topic: 5 lug conversion (Read 1725 times) previous topic - next topic
5 lug conversion
I just completed the 5 lug conversion on the front wheels of my 84.  I used 95 spindles, 99 calipers & hoses, sn95 inner and outer tie rods.  My question is did anyone have a problem with the tie rods bottoming out when adjusting them?
I have the outer tie rods turned all the way in and still have the front wheels toed out.  I am hoping I can take care of this when I align it.  If not the only thing I can do is cut a 1/2" to an 1" of thread off each inner.
I went with a less flashy look.  I used 15x6.5 1990 Lincoln Towncar steel wheels with 235/60R15.  I painted them up semi-flat with chrome lugnuts.  I have 15x10 steel chrysler wheels for the rear.  I hope I can fit all that wheel under the ass end. 295/50R15 on the rear.
I will post pics of the front soon.
Dave
5 lug conversion
I cut off a little bit on my inners when I did my conversion. Thread a couple of nuts on, lock them down and use a cutoff wheel up against the outer nut. Take the nuts off and the cutoff threads will clean right up.
1988 T/C body with a 5.0 transplant. Motor has a Vortech V-2 supercharger, Edlebrock Performer RPM II intake, heads, FRPP F-303 cam, Comp Cams roller rockers, Power Pipe, LMAF, full Mac exhaust, lowered, Koni's, 5 lug conversion, Cobra wheels, 13" Cobra brakes, etc.
SOLD September 2020. Will miss this car after 19 years of building/driving/showing it off. Time for a new chapter in my life.
Dynoed 446 horse/409 torque at the wheels.
2003 Tenth Anniversary Cobra Convertible. 1 of 369 Torch Red made.
2021 Chevrolet 3500 dually, crew cab Duramax.
5 lug conversion
Why would you go 5 lug then use steel wheels?????????????????????
You should have just used stang 15" 4 lug steel wheels!!!
5 lug conversion
Quote from: dominator;202971
bigger, better brakes maybe? ;)
5lug steels are also easier to find, we just had that discussion....
5 lug conversion
Stangs never had 15" steelies. Only 14".
5 lug conversion
steels are a classic look expecially if accented by chrome lugnuts or dog dish hubcaps. post some pics if u can. Are u goin wth a retro look overall or just waiting to get alloys? id like to see a retro bird flat black with steels siting up high in the rear and maybe sidepipes. it would be a one of a kind.
