Topic: My car sucks. (Read 1583 times) previous topic - next topic
My car sucks.
I finaly put a cheap ler on my car, but it does nothing, it's a little quieter, but the exhaust leak at the passanger exhaust manifold is still so loud it drowns out everything else. I think it may be the joint. I'm heading up to my girlfriends dads shop tomorrow to remove my entire exhaust to figure out what's wrong.
I'm gonna remove my precats and just inspect them. Do some welding if I have to. I'm also gonna patch up my exhaust and put my ler on so it doesn't s the ground.
I was under my car today and I was just inspecting everything, I was tightening up my tranny pan bolts, they were all a little loose. I got to one screw and didn't even get the rachet around the bolt and it fell right out. Now, how did the bolt stay in when going over bumps? It was a paint to get back in but it seems like it stopped leaking.
I also tore off the side molding, the passenger side the paint is like chipping off badly so I need to take a razor blade and remove the sticky stuff and paint and prime it cause it's rusty.
Re: My car sucks.
check to see if your smog pump pipe came off your pass side exhaust pipe.  If so, you'll leak bad there cause the hole is about 3/4''
where'd you get that avitar,,,, :D
