Topic: Mid/low 13sec 5.0 project (new video and pics 7/11) (Read 249705 times) previous topic - next topic
Reply #390
So I'm about to get the last few parts needed for the project.  But first, a few questions:
1)  There are two types of motor mounts at autozone, hydraulic and solid.  Which should I get?
2)  When getting my fuel pump (walbro 255lph), should I get just the pump itself or a kit?  http://www.apeusa.com has both flavors.
Reply #391
i would get the kit because you get the fuel sock and some other stuff. which is better than trying to match up your stock fuel sock or one from a parts store.
Reply #392
Very nice indeed.
Whoa, that was fun!
Reply #393
Get the "Hydraulic"  mounts.Solid will give too much vibration.I personally like it as smooth as possible.It's all about personal taste.
Reply #394
Ok thanks for the info guys :)
Reply #395
The hydraulic probably won't last long with power, mine didn't.
Chuck w's work great with minimal vibration. I think he's out of them though.
Reply #396
Quote from: Kitz Kat;252811
X2 on that....  you MIGHT get a year from the hydraulic mounts afte motor is done....  Get some of Chucks....  thats what I need to get this spring.
Reply #397
Chuck's mounts are too expensive for me.  So would I just be better off with the solid ones?
Reply #398
Where did you find solid mounts for a '88 tbird?
1979 Ford Fairmont
[/B]
Reply #399
Quote from: 32VFoxBird;252828
I was curious about that to.
Reply #400
The insulator is the same as used on '89-? 3.8 Birds, should be readily avaliable... AFIK it's solid(rubber)and the hydraulic mounts were only used on Turbo Coupes to reduce vibration of the half motor...
Reply #401
The 89-? 3.8 Bird/Coug use the same insulator as the '86-'88 5.0 cars, should be no problem to find... AFIK they are solid rubber and do not transfer vibration(I believe the liquid ones were only used on Turbo Coupes)... Had a set in my Bird since '99, but I have a additional limiter bracket to keep the engine torque from twisting the left side more than 1/4"...
Reply #402
http://www.autozone.com/R,4900508/vehicleId,1070903/initialAction,partProductDetail/store,1287/partType,00154/shopping/partProductDetail.htm
There are also hydraulic versions.
As for the comment about the MN12 3.8 Tbird mounts...so do you mean the whole mount works, or just the insulation?
Reply #403
I got new solid mounts. One from napa, one from pep boys. Both ripped while the engine was just sitting in the car for a couple of months. The car was only driven on the street a handful of times, and it was quite literally around the block. I didn't do any neutral revs, or clutch drops or anything. Did squel the tires once or twice.
When I pulled the motor out when the tranny went out, both my rubbers were broke. And I loosened the bolts on the motor mounts, and was very careful when I started jacking it up. I did not tear them using the engine jack.
Reply #404
Interesting... I've got 3 years on stock type mounts with my current setup.  I have a torque arm from the transmission bellhousing as well though...
A set of Chuck W mounts is waiting for when they are needed....
