Topic: Mid/low 13sec 5.0 project (new video and pics 7/11) (Read 249653 times) previous topic - next topic
Reply #375
Finished paying for the engine work today.  Got my heads back too.  He cleaned and resurfaced them free of charge!
Reply #376
look B/A
Reply #377
Did ya get a new oil pan or are you reuseing the stock one?
Reply #378
Reusing the stock one and cleaning it up.
Reply #379
Man I'm getting my car painted but now I want to build a motor after seeing your pictures!  Looking good man...your car is without a doubt getting better all the time.
Reply #380
You know what that block needs? A nice, shiney coat of Ford Blue engine paint ;)
Reply #381
Quote from: thunderjet302;248018
I loves me some of that Ford Blue.The dark Ford blue.
Reply #382
I'm just gonna paint the block black.  Won't show the dirt and grime as bad, and you really don't see it much anyway.  The valve covers will be ford blue though :) .
Reply #383
Woke up early this morning so dad and I could start piecing together the short block.  We took our time, checked everything over.  Plastiguaged all of the clearances; they were dead on spec.  Prepped the pistons, rings, and bearings, and started putting them in.  About halfway through, we noticed some of the number markings on the rods weren't facing the right direction, but everything was fitting right so we kept going.  Once we got to #5 and #7, however, they wouldn't fit.  At first, we thought the rods were installed backwards; the numbers were on the "wrong" side and if we installed them backwards, they fit perfectly.  Called up the machine shop guy, and it turns out he had them numbered 1-2-3-4  5-6-7-8 instead of 1-3-5-7  2-4-6-8 (like how dad is used to building SBCs... Chevy guys :p ).  Anyways, we took all of the pistons out (except for #1...that one was at least right!) and got them in properly.  Other than that mistake on our part, everything went smooth.  Here comes the horde of pics!
Dad explaining some things to my friend and I.
Crank is in!
My friend and I getting the hang of installing the piston rings.
2 guys you do NOT wanna see working on your car :hick:
Pistons are in...with "5" and "7" being backwards.
Now they're in properly...gotta love the piston comin way up!  <3 compression
Ok, I just HAD to see how the heads and rockers were gonna look.  Couldn't help myself.  :D
Really happy with the progress so far.  However, we were doing some final cam research since I plan to order it in the next week or two.  Turns out there are multiple versions of the XE264.  One is for nitrous use, but the other is said to be designed for use with 1.7 rockers and is a great HO replacement cam.  Sounds like a perfect glove fit for my combo, check it out:
Comp XE264
^Sure seems like the perfect fit for my setup.
Anyways, that's it for now.  Just gotta do a few odds and ends, then finish saving up for the cam and fuel pump.  We plan to FINALLY fix my cruise control tomorrow though.
Reply #384
Awesome work man.  You must be as excited as a kid on christmas morning right now!  Looks sinister with the heads on it...I expect more youtube videos to be posted once this thing is up and running!!:evilgrin:
Reply #385
Quote from: 50tbrd88;249030
You bet!  I'm STILL grinning ear to ear.  Nice to see everything starting to pay off.
Oh definitely!  The heads will stand out even more once the block is painted black :) .
Hehehehe....muahahahaha :evilgrin:
Reply #386
You ready to convert to mass air?
Reply #387
looks great! i forget how tiny the 302 looks on a stand. how exciting its going to be to turn the key for the first time!
~John~
Reply #388
SAAAAAWWWEEEEEEEEET!!!!
Haha Mike musta been flippin out at least as much as you, better keep him away from there don't wanna wake up and walk out there to find the stand mysteriously empty :evilgrin: :evilgrin: :evilgrin:
Nice air compressor too btw!
Reply #389
Quote from: Haystack;249133
Nope, especially since I'm back to the stock cam now.  That Comp Cam requires stronger valve springs, and I simply can't afford it.  There are much more important things I need that money for.
Thanks for all the compliments, guys!  I'm really excited.
