Topic: It has begun.....UPDATE.. (Read 3495 times) previous topic - next topic
If I can use the E-7's and the E303,the 1.7's should be a breeze.It feels good to finally be done with that part of the Sport's build.Now,I can concentrate on getting my a/c pieces (trying to re-install the system from scratch),and the 5 speed swapped.I have the pedals.The tranny and bell housing are in route.I'll buy the clutch,cable,etc. over time.I also need to have the Sport painted as well.Probably before the 5 speed.I'm really getting tired of seeing the red,blue,gold and primer.LOL.
How hard is it to do that?I have NEVER messed with the gears or clutches or any of that.Swapping axles and bearings are about it.
Easy, than what your doin to the engine.
You goy my # call me.
Just don't over rev it and float the valves... I bettin' you'll have pistons kissing valves...
Figure it's going to have to idle at least 800-900 RPMs...
Quote from: TurboCoupe50;202382
Funny on the quote I see kissin valves,not in the message.
He did ptv the cylinders though I don't know how close they were?
What are you calling "over revving"?I probably won't hardly ever see 4500 or 5000 rpms.90% of the Sports life is just going to work about a mile away,picking up the boy from school and going home.RARELY is there a little "stoplight action".
I must of missed that!
Oh,Kitz,PM me a little info on swapping the clutches in the 8.8.Just to give me an idea of what I'll be doing.
Vinnie you do have upgraded springs?
Yes,he added new springs when he did the valve job and porting.
No problem, Vinnie
Awesome vin!!
Did u get that 20 i sent to you?
I did get it,Mason.My opologies for not letting you know.I've had my head in the clouds with all that's been going on around here lately.Thanks.
Hell with the mild cam in mine (@.050 210I/215E, lift .533I/.533E) I have to have it idle at 1050 rpms in park and about 800 rpms in drive when hot or it gets all surgy and stalls when I shift from drive to reverse.
Nice to know its done. Now fix the rear so you can do this :burnout:
Quote from: vinnietbird;202397
Np just wanted to make sure its all set!
