Topic: TC spring question.... (Read 1837 times) previous topic - next topic
Is thwere a differnce between TC rear springs and the springs on a Sport ('88 model)?
Can't answer your question.but could you measure the length of the tc's?
I will when we swap the rear out....again.
Nope... My '87 Sport had the same part no on the tags as most TC's...
My white TC has different codes(front & rear) than any other '87 -'88 TC I've seen... Difference??? Not A clue...
Obviously front springs are different between the two... My front is now approx 3/4" lower with the 5.0...
Thanks.I mainly want to lower the front by about an inch to an inch and a half.
With a iron headed engine you should come close to 1"...
Get some from a 5 speed, should be lighter than a automatic version...
10-4.Thanks a lot.
Quote from: TurboCoupe50;202367
Try finding #'s for them.I really don't think they are available.
Check mooge or anyware,whats the difference ?
Quote from: kitzdnm;202414
Beats me but if you check the Ford shop manual there are probably a dozen different springs for front and rear...
Likely some are just a few lbs different from the other... As I stated my white TC has different spring codes than any I've seen & I've owned 14 of 'em...
