Topic: dead pedal (Read 1693 times) previous topic - next topic
dead pedal
its been a few years since i held a mustang dead pedal in my hands. is there a snowballs chance that it would will bolt into my 87 tbird, or am i gonna hafta build a bracket?
finished puttin the interior together last night, and whilst sittin in the car i noticed i could really use one. the floot well is a good bit deeper than the clutch pedal.
dead pedal
I have a couple in the garage I "procured" from probably the same place you did.  A bracket, or at least some spacers behind it might be needed.  It's been a little bit since I looked at it.
dead pedal
OK, there are actually two different Mustang dead pedals. The two mounting holes are different from each other, and the pad attaches differently between them. Just so you know. :) But in either case you can definitely make them work on your car. IIRC I used some self-tapping screws. There are no pre-drilled holes for them, nor are there any indents in the kick panel metal, so it's line it up by eyesight and drill. I put mine high enough so that the floormat could get shoved under the pedal and stay put. Mustangs, I believe, have the pedal right down to the carpeting.
dead pedal
I have one in my '88.
dead pedal
thanks for the info guys. i was sure i could make it work, i jus dont currently have one to look at. those dead pedals have made thier way into a lot of non-mustangs....
the real question is, do i head over to the dealer for one or drive across town and steal one from chuck? :moon:
dead pedal
You open my garage and the alarm will go off ;)
Let me see how many I have.
dead pedal
Quote from: vinnietbird;201359
Vinnie what year Mustang is that from? I might put one in my 88.....
dead pedal
Some late 80's Stang.I probably have one or two out in the garage,the trouble is,finding it.My garage is packed right now with everything I have going on with the Sport.I'll try to find it.If I do,I'll ship it out to you.I'll never need it (I have one already).
dead pedal
Gumby.....I have 3 in the garage.  One is yours.
dead pedal
very cool! ill give ya a call after i finish my household cs :p
dead pedal
Quote from: vinnietbird;201595
If ya ever find it let me know:D
dead pedal
I've got a few cs to do.I will find it.Just PM me your address and I'll ship it when I find it.Also remind me in the PM what you need.
dead pedal
I had one from FMS in my 87 Sport. I thought it bolted right in, but I may have had to drill a hole or something.
