Topic: sticky drum brakes (Read 1594 times) previous topic - next topic
sticky drum brakes
Not that I'm looking to redo my brakes, since I will be swapping an 8.8 in around spring. But I'm just curious if any other fox owners experience this.
When its extremely cold, my brakes are perfect.
When its extremely hot, my brakes are perfect.
When its extremely slippery, my tires never lock.
If it has rained for more than 30 minutes, my rear tires lock up like there is no tomorrow.
For example, when I pull out of my space at school... I roll up to a 3 way intersection and touch the brakes to slow my roll (not that I'm going faster than 15 anyway) and the rear tires lock up like they would on the freeway if you slammed the brakes.
after sitting in a line of stop and go traffic for 10 mins trying to get out of school, they loosen up and are safe to drive on.
whats going on back there? lol
The only thing i can think of is maybe the springs slip around?
again I'm not looking to do a brake job, I was just curious if anyone else experienced this.
1988 T-Bird LX- Awaiting HO build, Monster "Eat My Shift" AOD rated 550Hp. BBK ceramic shorties, Jegs mustang (catless) H-Pipe. mustang catback modified axle back for tbird, 94 17" Cobra wheels, 98 'Stang GT 8.8 Traction-lock
sticky drum brakes
once you make that initial stop and your tires lock, does the problem go away? if thats all it is it might just be a little rust on the drums and poor quality shoes. but even then i wouldnt think they'd 'lock'.
if they keep locking a couple stops in a row it might be more serious.
its odd how you said that this problem doesnt occur even when slippery. thats why i think its a rust related thing and not like a prop valve, or that should be happening all the time.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
sticky drum brakes
ive put 6000 miles on the brakes since it was parked back in august, so maybe your saying rust in the springs?
it has new pistons and stainless lines from the doors back.
And by lock, they lock lol.
In a fashion where I'm afraid the guy behind me thinks I'm brake checking him.
it does it a few times in a row, but when i finally get out of the lot they get full pedal.
the last time this happened was when i first started driving it, i would pull out of my driveway and hit 25, then if my foot tapped the brake pedal the right rear would bark.
Maybe if I pump the e-brake a few times it will loosen up before I drive? hmmm
but after those first couple times it never happens.
sticky drum brakes
check for brake fluid contanimation on the shoes. if you replaced a wheel cylinder in the past and not the shoes the fluid can soak into the shoes. or you may have a leaky wheel cyl. my truck does this until the brakes get a little heat in them. i need to change the shoes but i drive the truck so little now i just ride the brakes down my street and then all is fine.
louie  :birdsmily:
My famous last words:
sticky drum brakes
try this.  put both rear tires in the air, take the rear tires off and then the drums off (just the outer drums which are bolted sequential with the rims) and inspect the shoes.  if you see excessive rust or contamination, change them, otherwise just blow them off if its minor contamination like a lil bit of rust etc.  if you dont have access to air aka tank n gun, go to a computer store like staples, etc and get the keyboard compressed air and as long as you hold the can upright only air comes out.  before you do ANY of that tho, try putting it in reverse and go backwards 10 times, each time hitting the brakes to come to a stop.  if they still lock after that its time to get your hands dirty.  btw, drum shoes are really inexpensive.
