Topic: AOD to T-5 swap is right here everything you need!!! (Read 1035 times) previous topic - next topic
Okay parts are now for sale
t-5 setup
includes flywheel, king cobra clutch, pressure plate, throw-out bearing, fork, cable, bellhousing, clutch pedel assy, t5 tranny and steeda tri-ax shifter w/ . shifter bezel plate for 5 speed tranny for tc center console. Pedal assy also has a steeda quadrant attached to it.
tranny is about 4-5 years on a rebuild, it shifts great and goes into all the gears without any problem. It does have a slight whine to it but its been that way for years so I don't think its a problem. It might be from the aftermarket shift and do to the fact I don't have all the insolation and rubber piece over the shifter. Also have the steering column cover for those that will be using this on a tbird/cougar that had a column shifter and this cover doesn't have the hole.
The flywheel, clutch, throwout bearing, and pressure plate were all replaced in August 2006 and have 10k miles on them.
I'm also including the transmission crossmember which also have a solid poly tranny mount on it. Also have the reverse backup harness for it too.
If I missed anything let me know cause I have it all.
I'm pulling everything from the car this week so I will post pictures in a couple of days when I have everything out. I'll save every nut and bolt to keep everything complete.
I'm looking for $800 obo
Was this out of a TC or a 5.0 stang?
v8 tranny. I'll look for the reciept from the rebuild and post it. I think it was 2003 it was done.. I'll look now.
I found it here it is..
will you ship? taxes are coming up...
I will ship, I have a sale pending just waiting till next week to work out the wieght and crate size. I'll let you know if it falls through
please do :)
added pics.
missing from the pictures but included is the pedal assy and shifter bezel plate (those pics are coming)
more pics :)
I might be using this tranny on another car, I will re-post them if they are for sale again.
