Topic: Front rotors (Read 1617 times) previous topic - next topic
Front rotors
Have a 88 Turbo COupe. Wondering if the Front rotors on a 90 Mark VII would slide on the spindles to make it five bolt.
:birdsmily: Nate Wenck
Carroll IA
nwenck@msn.com
07 Suzuki Boulevard C50T
2003 Ford F-150 Supercrew
Front rotors
yes
Front rotors
Thanks I thought so, wanted to make sure.
Carroll IA
nwenck@msn.com
Front rotors
if i remember right the rear brakes will work just the axel's from the mark are longer. i remember a thread about rear disk about a year ago. they had all the good info on what you need to make rear disk with several different parts.
Front rotors
I have a complete Mark VII rear end that will go under my bird, after I regear it of course.
Carroll IA
nwenck@msn.com
Front rotors
Quote from: ipsd;200940
Does anyone have a link to that thread?  I'm interested in doing this swap on the rear of my TC.
William
Front rotors
http://www.coolcats.net/tech/advanced/4to5lug.html
1984-92 Mark VII Rear Discs
The Mark VII was one of the first cars in the U.S. to offer ABS braking, which usually requires 4-wheel disc brakes. Not all Mark VII's had rear discs though---some had drums, so be careful when checking them out. The Mark VII, as with a lot of Lincoln components, had their own unique 10.5" rear discs through 1990. This means you would need to use Mark VII rotors, calipers, pads, brackets and bolts. From what we understand it's not simple to do the Mark VII rear disc swap.
Front rotors
Maybe this will help you out.
http://www.factoryfive.com/table/whatsnew/tech/brakeadvice.html
