Topic: Vibration in floor and gas pedal (Read 2740 times) previous topic - next topic
Hey guys.  I have an '86 Cougar 5.0 and i'm having a strange problem.  Whenever I drive the car now, I can feel this hum or vibration in the floor and on the gas pedal when I first press down on it.  When i'm cruising and I let off the gas I can feel it too.  I put my head under the car and I can hear it when the car is still and idling.  It's a low hum or buzz coming from somewhere near the driver's side firewall.  Since this problem started i've been having problems with the car stalling a lot.  Especially when i'm at a full stop and go to make a turn.  What could this be?  I was going to change the front struts tomorrow...should I wait and do it after this is taken care of?  Don't want to mess anything else up.  Sorry for the long post...  Thanks! :flame:
Re: Vibration in floor and gas pedal
yeah, id wait till you figure this out.
you lost me when you switched from Hummm to Buzzz.
try and re-describe
only thing coming to mind is motor or tranny mount  and its a definate maybe
It's a low level hum...like 2 things are rubbing together and creating friction.  I can feel it in the floor, gas pedal, and shifter.  If I accelerate hard I don't feel it, but as soon as I let off the gas I can hear and feel it again.  Sounds like it's coming from somewhere near the driver's front wheel or wheelwell.  I stuck my head under the car on that side and I can hear something humming near the bottom.  Sounds like it's close to the cat coming off of the exhaust manifold.  Can't think of any other way to describe it.
By the way, just had the motor mounts done a couple weeks ago.  The old one were totally shot and the brackets were both broken.  New mounts are working fine and engine looks to be sitting higher than it was before.  Could I have caused something to go out of adjustment or break when the new mounts went in?
humm,,,
see if your tranny/shifterlinkages along the firewall are not the problem.  If you have a TV rod,, check that also.
you just might have a loose braket but id sure wanna find out what it is first.
did the problem start right after the new mounts were installed?
Could the exhaust have been installed when the motor mount was bad? The new mount repositioned the motor and now the exhaust is rubbing something?
