Topic: transmission and speedo gear help? (Read 1314 times) previous topic - next topic
do they make a speedo gear for a c5 transmission so the 4:10 gears in the rear will read right with the speedometer or do i have to wait till i switch to aod later this year and be able to find one easier? will this work with my transmission? http://mustangunlimited.com/itemdy00.asp?T1=DFM17271J+01
instead of having to go to a floor shifter when i do the aod is there a way to leave it a column shifter?
are you sure you have a 7 tooth splined shaft? 23 teeth on the plastic gear is a lot. they usually get chewed off.
1979 Ford Fairmont
[/B]
i have know idea that why i was asking anyone that would know.
