Topic: Perhaps a headlight option.... (Read 4194 times) previous topic - next topic
http://www.retro-solutions.com/hid.html
Custom jobs....Expensivo however....
I wonder how much.I have no idea which projector,or bulb,or ballast to decide what I want.It's all foreign to me.any idea on cast for a typical job on T-Bird lights?
I priced sending a set of my own headlamps in for an HID conversion with angel eyes...It was $700+.  I've seen some of his work...Top notch, but that's a custom cam and the 3.45's and drag radials...
one thng about retrofitting our headlights with true HID's from my understanding of them, our entire headlight bucket/lens assembly would melt under the temp loads that HID is responsible.  if there was a way to make the headlight buckets out of glass and retro fit HID's within the housings, it'd be pretty pricey.  High Intensity Discharge, if you didnt already know.  now it may be different on some headlights b/c i seem to remember some using plastic, but im pretty sure the plastic even the NOS headlights are made out of seem they would melt.  They're not just projector headlights like aftermarket WANNA BE HID headlights.
Dont hold it to me with this info, b/c this is what i've been told by a couple friends that are into cars with factory HID's.  They could be wrong, but i trust them since i dont have 700+ to give it a shot myself.  also most of the HID kits dont come with 100% of the parts a standard HID system would stock..  heard of stuff like they need a balast per HID and the retro cheapo kits come with 1 per system type of stuff.  also i've noticed true "retrofits" go into glass housings on lexus and nissan/infinities.
i emailed the company with a few questions that were brought up here and i can post what is said.
Got that fox rash again!
-Resident smartass! :ies:
Problem with HID conversion in these cars: Kiss your high beams goodbye. HID headlights do not have provisions for dual-beams, and can only be installed in cars with four headlights so that two can be used for high beams and two for low beams (or more common, two for low beams and two regular bulbs for high beams).
Yep, so they would work great for the 83 - 86's ;)
Not a good idea
The light source (arc) in HID lamps is not at the same position nor of the same orientation as that used in our older lamps. HID requires lenses and reflectors designed for the light source characteristics to be  properly focused. At best you would get a light that would not be as good as a properly designed lamp and likely not better than what you have, and at worst, a beam that will be glaring to oncoming traffic. If you can't get an HID assembly designed as a unit, it's going to be subpar and likely dangerous to other drivers!
Of possibly minor concern, it's also against Federal and State lighting regulations.
Quote from: Thunder Chicken;199863
Actually, there are kits that now have provisions for high beams. They work by having a solenoid that angles the bulb itself.
Quote from: baxo;199864
thats right beeoches 4 eyed pride.......woop woop:shakeass:
there also illegal in most areas, due to them not being DOT approved.
1979 Ford Fairmont
[/B]
How is it done in the '08 Mustang then?
The H3 HID kit looks tempting. My H3 fog lamp bulbs don't give off squat for light.
5.0L Speed density
Explorer intake
'92 Mustang GT cam
GT-40 racing heads
Unequal length headers
Custom-made duals
19# injectors
65mm TB
AFPR
T/C header panel
11" brake upgrade
T/C rear sway bar
