Topic: Converting a t5 bird to a4ld tranny (Read 3687 times) previous topic - next topic
What is needed to do this conversion I have the tranny the converter and everything. What I want to know is if the connectors that go to the tranny needed and what are they for only for the lockup of the converter or what else. Also is this harness seperate or is it together with the engine harness?
87 T-Bird turbo'd and supercharged and if things call for it juiced. :evilgrin:
88 Turbocoupe t3, 4.10's, Daily driver
why?
1987 TC
You need to decrease your hp so you don't blow it up
GT40p 5.0 w/ vortech @ 9.5psi, 400rwhp
I would not choose to use an A4LD man, but just in case, the connector os for the OD, and the Lockup if I am remembering correctly.  I know for sure it's for the 4th gear, and I know that it has 3 terminals in that plug, that I belive are 3-4, lockup, and ground.  Its just been so long since I have done one of those, hard to recall.
Matt :tg:
A4LD connectors changed after 1987.
1987 TC
If you're gonna go with an automatic, go with a C4. The A4LD is weak.
Quote from: 87thunderbirdBlackJack;199012
why?
He needs an A4ld in one of his cars
Quote from: SLEEPER T-BIRD 87;199150
Nobody needs one of those transmissions dude, those things are turds.:toilet:  Even though the '05 and newer Mustang uses a trans that can be traced back to the A4LD, they have been greatly improved upon.
Matt :tg:
I need the to convert the car to the a4ld because the person who is gonna use it is not gonna be racing or nothing. Also because she wants it automatic so all the help you can give me is greatly appreciated.
The A4LD is different from the Mustang to the TCs... The Stang only uses the EEC to give OD... The Bird trans also has has the lockup converter controlled by the EEC... Reason I know this, I sold my A4LD to a friend for a '88 Mustang, he had to swap the valve bodies and the plug on the transmission to make it work...
I assume you know you'll need a automatic EEC...
Also you'll need a shorter driveshaft, plus the A4LD cross member and brackets that bolt it to the frame rails.. The std cross member mounting for the T5/AOD C/M cannot be used due to the much longer A4LD...
A much easier conversion would be the C4.  The A4LD is just not what you are looking for man.
Matt :tg:
The name says it all man... Automatic 4 Light Duty :D
Matt
Theres nothing about lite duty with C4,thats one of the toughest trans ford made.But he did say he wanted OD.
i never thought i'd see this post! i am in the process of swapping my a4ld to a 5-speed.  you will need the automatic computer as well as the tranny wiring harness from an automatic car as well as the vacuum lines. my a4ld is on the floor and i dont dare sell it as i'd get laughed at.
