Topic: wtb or trade cams (Read 1237 times) previous topic - next topic
wtb or trade cams
I have a cam that is wayyyyy too agressive for EFI.  A carb guy could get away with this cam but not me.
Its very old but used very little.  I know it sat for a few years in its box before we put it in a friend of mine's engine and said engine is now in my white coug.
The brand was at that time "blue racer" which has been integrated into another company by now.
the numbers are below but you have to zoom in.
cam lift is .496intake and .520exhaust
cam duration is 290intake and 300exhaust
wtb or trade cams
is it a roller or flat? soild? might  be interested if its a solid. Blue racer is still avaliable at autozone
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
wtb or trade cams
its not a roller.
Im using hyd lifters in it now.
Im looking for an F cam if you have a lead.
wtb or trade cams
That cam should work fine with efi.
An f-cam is more agressive than that 512/512 and 288 duration.
Sounds like your cam has better exaust scavenging
Pick up a trickflow stage1 or at the very least an E-cam and stay away from the F-cam.
wtb or trade cams
well i should have the f-cam out of my engine soon so i will keep ya posted!
wtb or trade cams
I have an E Cam, 220/220, 498/498  @110 LSA w/1.6 rocker and 1995 Cobra cam (which is a Crane 2031), 214/220,.513/.529",112LSA w/1.7 rocker (lift is 483/498 w/1.6 rockers).  Either one $125 shipped.
wtb or trade cams
Scott what are the ICL,ECL and LSA for that cam?
It looks to be this one:
Wolverine / Blue Racer
 WG1037
 ADV. INT. -290°
 ADV. EXH. - 300°
 .050 INT. - 224°
 .050 EXH. - 234°
 int. lift - 0.496''
 exh lift - 0.520''
 lobe center exh/int - 107° / 117°
 basic RPM range - 2,000 - 4,800
Those lobe centers work out to a 112° LSA
By EFI do you mean Speed Density?
wtb or trade cams
EFI
meaning ,, it is too much for an EFI setup.  WIth a carb'd setup it would work fine as it did with the 750 holley.
sorry on the late response,, im seriously in the market for a cam right now and hoping for an HO one soon if it goes through.
What do you make of the cam i posted up?  your technical thoughts on its intended application based on all the the good research you've done?
wtb or trade cams
IF you want a smaller cam go buy a steeda cam #18 about the same is a B cam.
If you want a cam about like that one but maybe a little better get a Trick flow stage 1 cam.
wtb or trade cams
That cam would work with Mass Air....Problem is it's not a roller.....IIRC that cam was actually marketed as a Ford Racing cam years back.  What are you looking to do?  Full HO conversion?  There are a couple of roller cams with the SO firing order that are a wee bit more aggresive than an HO cam....
wtb or trade cams
Quote from: V8Demon;216933
,, the block is not rolller.
wtb or trade cams
Just what exactly are you stuffing the cam into if I may inquire?
wtb or trade cams
into my failed project back in engine swapping from a long while ago.
not interested in going MAF at this time,, keeping it sd.
short skinny,,, all of this is for the white coug in my sig previously wired and equiped with 3.8L cfi.
66 289 heads shaved .020 ported polished @54cc
1.4xI,,1.9xE valves
1.6 roller rockers
.040 over block w/pistons
high vol oil pump
I have,,,
HO upper and lower w/ spacer
Dizzy
MarkIV eec HO
BBK headers
fuel rail
coolant rail
domed shaped pentel 19lb injectors, org top
stock TB  which i would like to change to larger
dont have
an ho cam
engine or eec harness
