Topic: Shocks & struts...who has what (Read 2638 times) previous topic - next topic
Just wondering who has aftermarket (or swapped OE) struts & shocks on their cars, and if so what brand, etc, and how do you like them?
I'm thinking about pitching my PRC struts & shocks once and for all, the strut mount bushings are squeaking like crazy anymore and driving me nuts.
I have some of Chuck's shock brackets, so I've been looking at 87-93 Stang Tokicos and KYB's....I have to admit, the price of a set of KYB GR-2's is tempting, but I have to wonder how good they are. Even the AGX's are pretty cheap for adjustable shocks & struts.
My car is also lowered so I'm curious how that will affect things...
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Nothing too fancy for me...monroe sensa-trac's on all 4 corners along with KYB's for the quad shocks...very good ride for the street which is the main purpose for me.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
Quote from: slicksport88;197847
Have Sensa-Tracs myself and I like them. Nice ride but also firm at the same time.
Stock and stock for now was thinking of getting KYB shocks and struts and some ford racing springs.
I have the KYB's front and rear w/Eibach lowering springs.  Ride is firm, not harsh.  An easy intall.  I am pleased with the combination.
Generally, KYB's are junk, but feel firm when you replace 20 year old stocks and struts.
A friend of mine used KYB GR2's in his 90 Trans Am. He swapped to some Bilsteins, and it was a night and day difference.
Tokico's are supposed to be a little bit more firm than stock.
I have Koni reds for TC's. I have them on a 88TC. I have them adjusted to only 2 turns and the ride is ok and hadled great. I then went to front coilovers with the kitw/springs from MM and tubular lower control arms up front. Ride is a little more frim with the same shock settings. Handles even better. I will be going to coilovers in the back also. However I think I will go with the double actions konis out back and then up front. The coilover set-up is worth every penny. You do have to go to the CC plates with the coilover set-up.
Santana
Eh, I dunno about laying out the cash for coilovers right now, maybe down the road a bit.
Garrett H.
Exhaust sound clip
Another clip
I bought the coilover kit but it did not work with my t-bird struts so I had to hit the junk yard and get mustang strut hardware but atleast I got to run the poly mounts very firm ride
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
pics
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
for my cougar i am using lakewood drag struts and shocks and poly-urathane bushings all around. that setup is awesome.
 shock are 50/50 and struts are 70/30.
Koni DA's and Griggs Coil overs up front and Koni SA's and Griggs coil overs in the rear.
Ran the KYB's and I thought they were junk.  Tokico Illuminas or D-Specs would be a great option and not break the bank.  Just remember to put some good springs in it as well.
Darren
Stock for now, want to do coilovers in the future, when I get a k-member.
:birdsmily: Nate Wenck
Carroll IA
nwenck@msn.com
07 Suzuki Boulevard C50T
2003 Ford F-150 Supercrew
