Topic: will BBK equal length shortie headers fit 87'-88' tbird (Read 2829 times) previous topic - next topic
The title says it all. I have a set to put on, but I'm wondering if the motor mounts are going to give me a problem.They're designed to clear a mustang's mounts, but I'm not so shure about our py
mounts...
Re: will BBK equal length shortie headers fit 87'-88' tbird
stock mustang headers are a tight fit with the tbird mounts. i had to heat and bent down the "shackle" (passenger side) for the stock mustang headers to fit. my guess is that the equal length ones wont. seeing as you already have them it would only cost you time to try them.
~John~
I've been using shortie equals for years,they will fit but are a hell of a tight fit, some modification has to be done to the header tube to clear the steering shaft as well as the motor mount shakle on the drs side.
They do fit, but all i gotta say id have fun,their a #$@^.
are equals even realy worth it? what kind of gain would you get over same size un-equals?
~John~
Not much of a difference, they'll give you a little more on the high end.
If i had to do it agin i'd go with unequals.
My brother thinks that I will have to take the equal length headers off to change the spark plugs.  Does anyone know about this?
Not true..you can change spark plugs just fine with equals or unequals.
Just my $.02....unequals look way cooler. :D
basically if you want closest to direct bolt-on, you're better off with unequal length headers. if you have time and the ability, you can make the equals work
