Topic: Lets see your tailpipes (Read 8024 times) previous topic - next topic
Reply #45
No pics today.The passenger side tip was too long and would hit the gas tank,so,new tips on the way,and updates as they happen.You heard it here first.
Reply #46
3" dynomax bullets (to mimick converters) 3" X pipe 3" 1 chamber flows
Flowmaster universal tailpipe kit,Stainless 3" tips
All done at home and it has a unique tone now
Opinions?
other then the car is nasty and needs waxed:D
Reply #47
 snow
Reply #48
Does the rear end ever hit the tailpipes?That setup intrigues me.
Reply #49
Quote from: vinnietbird;198176
With it on the lift the rear does make light contact but nothing severe to cause damage.Absolutley no contact during driving.I was going to go over the axle but it is tight with 3" and i would have had to move my fuel lines and it still would had rubbed the control arms.
Reply #50
Sleeper: Is that with the SBC still installed? Looks nice!!
I want Stainless 3" Rolled Edge Tips and I want them to be vertical with the circular reverse lights on my car, the 83-84 tailights. Make it look that much more clean and nice. I'll have to go with a fuel cell though. I think the "pit" in the truck will make a nice place for a fuel cell.
Reply #51
Quote from: cougrrr302;198190
yep,and thanks the pics kinda make it look wierd
Reply #52
where did you get and how hard was it to install the aluminum gas lid?? I like it!!!!!!!!!!!!
Reply #53
Quote from: flipnbird;198193
Its from walmart (lol) made for 97 and newer ford trucks it is as close to the right diameter as i could find there dirt cheap (11.99) and made of stainless
Reply #54
I have a 2004 Bullitt Mustang fuel door for my Bird.It was on the Blue T-Bird that's on the banner up top.It took a little ingenuity,but worth the time.I'll install it on the Sport after paint.
Reply #55
Here is an older pic.  I have since eliminated the gaudy clamps.
Blueprinted 306, Thumper ported Canfield 195's, TLSR Camshaft, custom motor mounts, Parker funnelweb, Pro Systems Carburetor, Tremec 3550 II, 4.30 gears, Moser Axles, Team Z custom suspension with upper relocation brackets and anti roll bar.  At the track I run M/T 26/10's on Weld Star rims.
My pipes
Reply #56
Here is an older pic of the Cougar at Tri State Raceway.  I have since eliminated the gaudy clamps.
Reply #57
Nice Cat.I also like the missing side trim.That's what I'm doing with my Sport.
Reply #58
sleeper, lets hear a sound clip of it....
Reply #59
Um Side Pipes
