Topic: Lets see your tailpipes (Read 8105 times) previous topic - next topic
Cougar50 how do you like those M/T tires I’m strongly leaning to buying them.
Assuming you don’t drive in the rain.
And what size are they.
Quote from: slicksport88;197761
As requested  :D
Are those stock (well on Flowmaster tail pipes;) ) Mustang polished tips? If not where did you get 'em? I'm thinking those would look killer when I do my 2.5 cat back.....
Quote from: Innes;197787
I've used both 28" (225/60/15) & 26" (225/50/15) versions of those drag radials.
I love them - 1.6 second 60' times means dead-hooking off the line. And they are stable as a table @ 120 MPH at the top of the track. I just bought 295/45/17's for my new 17" x 9" wheels - I will drive on them full time - they are also great on the street (my car is forbidden from seeing rain.)
Quote from: thunderjet302;197790
I don't believe they were Mustang specific. I had my local exhaust shop order them for me. They measure 24" long by 2 1/2" diameter which is the longest they had .
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
If anyone is stealing my idea,here's the quick instructions and best way.....
1.Remove the bumper cover
2.Remove the fiberglass bumper
3.Cut the outer lower corner (or the whole bottom depending on the tips) of the bumper mount off
4.Cut out the necessarry area of the fiberglass bumper to clear the tips
5.Re-install the bumper with the remaining 2 or 3 bolts per side
6.fit the tips on for a "dry run"
7.Using a wax pencil (it'll rub off of your paint with no damage),mark the plastic to be removed from the bumper cover.Start a little small and work your area larger.That way,you don't ruin the bumper cover.I used my Dremell and an Exacto knife with a number 11 blade(it actually cuts the plastic pretty easy,I use it for the "fine tuning)
note...this step can be done with the cover on the car and just keep fitting the tips into the notched area of the cover for an excellent fit.I'll help in any way I can
Last step.....Give Vinnie credit for all of the notched T-Bird bumper covers.LOL
I HOPE to have my new tips on asap.Prepare to be amazed !!!
Quote from: slicksport88;197794
I'll have to check into that. Thanks:D  If you don't mind me asking how much did they run ya?
Here's the best shot I could get. I don't think they're to visible though.
I think i've got too much wheel. lol
Quote from: thunderjet302;197802
The price I paid was for the tips and for having them welded on, which ran me approx. $60-80.
Quote from: slicksport88;197818
That's not bad :D
There are some awesome tips on ebay.I like the ones with the rolled edges.It gives them a "finished" look (my opinion).You'll see.
Vinnie,
Do you have a shot of the entire rear with both exhausts visible?
__________________
Twin '85 TCs
White/ Grey 2-tone
Got flowmasters with mangaflow tips heres the pictures i could find really quick.
I'll check.I would take a new pic today,but,I cut off the Australian tips and enlarged the cutouts to make room for the new tips which are being welded on at 10:00 in the morning.Pics soon after.I'm going to check for a pic of the tips I had on.
O.K.,remember,the car is going through bodywork and a lot more.Here are the Australian tips before I cut them off today.I really liked them,but the new ones fit the theme I'm going for.
Looking good guys keep the pic coming really needing some side shots now
