Topic: 347 questions (Read 3247 times) previous topic - next topic
347 questions
so i plan on ordering the rotating assembly for my 347 this week and send it out to get it machined saturday. but before i actually buy the parts and screw myself over, i have some questions hopefully you all can answer cus i cant find them anywhere else in this forum.
the kit im looking at right now will be 10.5:1 compression ratio. kinda high. whats usually the most compression u can run on 93 octane? i think ill have to mix 93 and race fuel with 10.5 to 1, which would suck driving any distance with not many racing fuel stations around. to those who have done a 347 swap, did you get a kit capable of runing 93? i have 60cc heads btw.
also does anybody have a fuel injected 347? i've seen a few carbed ones out there. but im not sure which injectors to go with. i plan on getting this cam (http://store.summitracing.com/partdetail.asp?part=CCA%2D35%2D775%2D8&autoview=sku) with my 2.02/1.60 edelbrocks. would 30's do it? or would 36's be better? i have no idea to be honest.
thanks everybody.
Keith
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
347 questions
with aluminum heads i believe ive heard 11:1 compression depending on the cam.theres a with more rpm range cam its the x.e. 274 .555/.565 its part #is249-35-518-8 it has a range of 2200-6200rpm  needs a 2500 plus stall.id go to jegs cause u can see how big a stall it needs i think it doesnt show for that cam but with it u need aabout 3200 stall and gears if no gears it will be gutless just like my brothers camaro was....
347 questions
Lotta cam(will your springs handle it?)... I recommend the small Trick Flow, cheaper and plenty for a street driver... If you want more lift get a nice set of 1.7 rockers.. The savings on the cam will pay for half of it...
10.5 should be fine with aluminum heads...
347 questions
i was thinking of going the route of 1.7's, but i already bought 1.6 rollers and i really dont want to have to buy rockers twice. the springs on the head are the dual springs and will work with up to .60 of lift. and 10.5 will be fine with pump gas? wow, that really surprises me. how does them being aluminum heads or not make a difference?
347 questions
The amount of static compression you are able to run with pump gas is determined by the timing events of the camshaft.  Determining what will work with an off the shelf cam is a shot in the dark.  Based on my poor experiences with OTS cams and excellent results with custom cams, I recommend contacting a custom cam grinder.  The greatest part about a custom cam is the way it can be designed to meet your performance needs, around the parts you have assembled for your engine.  There is no doubt it's more expensive.  It was the best money I have ever spent on a performance part!  I have worked with Jay Allen at Camshaft Innovations on three engines.  He has you fill out an extensive build sheet listing all of the engine and drive train specifics as well as goals for the vehicle.  He will tell you what will will work, what won't work and what may need to be upgraded to get to your goals (i.e. injectors).  If you are looking to do it right the first time, this is the way to go.  I've been around the block trying to get by on the cheap.  It has led me to swapping parts and chasing gremlins trying to find the drivablity and performance to make the car fun.  I would have saved money if I had gone the custom route to begin with...
347 questions
i agree with you on the custom ground cam, i'm sure that would be EXCACTLY what i want in a cam, and in the engine altogether. but i simply cant afford that right now. im starting to count my nickels and dimes on this project. keep in mind, this project started out as a simple H.O. conversion, nothing more. one thing leads to another and i gain 45 cubes and alot bigger cam. needless to say, my budget wasnt too prepared for this.
i talked to a guy i work with whose raced cars all his life, and he said 10.5 should be ok with the right cam. and i can always adjust timing to compensate some. pretty much as long as i dont race it with pump gas, just cruising, it should be ok.
does that cam really sound too much? it did seem a touch high to me, but it also states that its made for the cylinder velocity of a 347, and i thought maybe i was getting thrown off from looking at 5.0 cams and that this wasnt too much. any advise on what spec of cam to get? i'll mostly just cruise around on summer weekends and car shows. maybe to a track a couple times. but as much money as im spending, i wanna KNOW that i have more then enough power to keep up with others at the track.
if i spend this much money and loose to every mustang and camaro that goes up against me. ill just go crazy
347 questions
don't run anything under 93!! when I was younger and poor I had to run 87 twice and both times I ran it I blew the head gasket. but I run 93 and I have the 10.5 compression setup but when I go racing it's all 110:burnout: :hick: P.S. still poor:D
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
347 questions
thank you. thats exactly what i wanted to know. i knew 87 wouldnt cut it. but i was hoping 93 would work in cruising/normal street use. awesome
did you buy yours as a kit or did you buy your parts individually?
this is the kit i plan on getting. if you notice anything that would screw me over, please tell me. i saw that its balanced and it have 2 valve reliefs. 2 things i was told be sure it has.
http://store.summitracing.com/partdetail.asp?part=ESP%2DB16422LA030&autoview=sku
thanks
347 questions
That one is not too bad my eagle kit came with forged JE pistons.One thing I set up with my machine shop was they clean then check for cracks then line hone and resurface and bore.Then I told them I need to notch the piston sleves and then to bring it back for a second clean and install freeze plugs and cam berrings.Try erwparts.com
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
347 questions
the machine shop i plan on using is one the shop i work at uses. i guess they gave me some sorta discount cus it'll be about $700 to have them do everything nessesary for the swap and have them build the bottom end. but thats minus decking and line honing. it only being a 60k mile block i dont feel its too nessesary, they said they can inspect how off each measurment is for $20 a peice. i might just have them inspect just for reassurance.
but for a comparison, another local shop was about $1400 to do the same things. and thats for a shop i have no reviews for. i know that my shops machine shop has good quality and trusted work.
what does notching the piston sleeve mean and what does it do?
347 questions
clearance for the longer stroke.I bought the 88 5.0 block from the machinist had it magnafluxed, line honed ,0 decked and installed cam bearings and freeze plugs all for $550. and then I assembled the rest because I don't trust anyone unless it's stuff I just can't do.(like machining)
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
347 questions
to be honest. im still pretty young. i know enough i can build the top end with little problems, but the bottom end would be too much for someone of my skill level. i know that tolerance are very minute and the slightest mistake can ruin the engine. i trust someone who does this for a living much more then i trust myself doing that kind of work.
i think i found a desent cam. i tried calling summit but thier technical support closes at 9.
http://store.summitracing.com/partdetail.asp?part=CCA%2D35%2D518%2D8&autoview=sku
that one doesnt seem as radical. and if that does seem like the right cam for me. would a 2400 stall converter be best?
i apologize for asking so many questions, i know i've asked alot. i just know you all have done this and you know what works and what wont. and i really do apritiate any help you can give me
keith
347 questions
http://store.summitracing.com/partdetail.asp?part=TFS%2D51402001&autoview=sku
This is the closest one to the one comp cams selected for me but I think I want to get the one larger then this one not sure yet.
As for the 2400 stall you won't even notice a difference from stock(had that before the 3000) I have a 3000 and I need more but my set up is a little more radical then yours.But if you need help call comp cams or crane they will ask you questions and you answer and they will tell you what you should run.You don't have to use their cam but it is a good start
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
347 questions
i called comp cams and they recomended this cam
http://www.compperformancegroupstores.com/store/merchant.mvc?Screen=PROD&Store_Code=CC&Product_Code=35-775-8&Category_Code=
i think that the one i posted earlier. thats alot of cam. they also said i might be able to run 24 lbs injectors if i boost the pressure up some, and that 30 lbs might be better. i'm almost worried now from you all saying how much cam that is. i guess it'd be ok right. comp cams should know thier stuff.
347 questions
wow, thats going to be lumpy sweet!!!!!!!!!
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
