Topic: BBK lowering spring? (Read 1582 times) previous topic - next topic
will the ones made for 79-93 mustang work? its a 1-1/4 drop. will these work on my car with no mods done to the suspension?
I have mustang "c" springs in my tc and that's about as low as I'd go.  The c springs are suppose to lower the front 0.875"-1.00" and the rear 0.50"-0.75".
As far as needing modification, I wouldn't think anything needs changing besides your alignment.
I believe the guys here said fox/stang springs up-front are good, but our rears stick out a little more needing a little more spring weight
I'm going to check the "Strongly Disagree" box, and if you had bothered to actually search yourself you would have come to the same conclusion.
I have used BBK fronts in mine, they dropped it a fair bit but it looks good.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
