Topic: Looking for a quality 3" cowl hood 83-86 T-Bird (Read 2097 times) previous topic - next topic
Hey guys I need some help! I am ready to buy my hood and http://www.carhoods.com just raised the price from $599.00 to $699.00.What in the heck am I going to do I need a hood asap, I am down to the wire on my paint job completion any help would be greatly appreciated.P.S. looking for one with a finished underside and NOT a pin on style, I still want to show off the engine LOL.:D
Thanks Jeremy
1986 T-bird
347 stroker motor
185 AFR Heads
TrickFlow cam 224/232-542/563
Victor Jr. intake CNC ported
Quickfuel Holley 800 cfm
Hooker 1-3/4 long tubes
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
UPR upper/lower control arms
Strange shocks/struts
26x10x15 M/T slicks
11.48@119.27
(coming soon Tremec 3550)
The Finished Product
Did you try this place. I know there's a lot of stuff here. I didn't check on hoods though
http://www.showcars-bodyparts.com/
If nothing there,
I believe Eric has a bunch of links on his site
Indeedy I do...it's all new and updated information also:
http://www.coolcats.net/modifying/hoods.html
You'd have to check the mfr. websites for current pricing. BTW, I'm running a U.S. Body Source hood and it has a finished underside. Might be the only one left out there that does.
I cant believe thats all the hoods they make for our birds.Eric what one do you have
1986 T-bird
347 stroker motor
185 AFR Heads
Custom built AOD
B&M 3000 stall
8.8 w/4.30 gears
26x10x15 M/T slicks
11.48@119.27
Quote from: EricCoolCats;196604
here ya go thunder :D
http://www.vfnfiberglass.com
The hood for my 86 is from US Body Source also. It has a finished underside and uses hinges. Mine is pinned at the front. You'd have to either use hood lifters or a prop rod with it.... I prefer a prop rod.
It looks like they're still available: http://www.usbody.com/
It's a nice hood... *EDIT* It's $699. Probably the one you were looking at... Nevermind. I'll leave this up for any thread searchers though.
My hood is from, http://www.usbody.com/ as well. They are pretty solid, since I have a very small crack created by ME trying to make it work with the front lock near the nose, my fault. Crack hasn't grown in 4 plus years here in SW Ohio since. That's allot of hot n cold weather as well, since we have ranged from the rare low 100's in the summer, down to minus mid 20's in mid Winter.
Show off ;)
or you can build your own.... ;)
