Topic: Reassessment of the 87 (Read 2139 times) previous topic - next topic
The thread about how much we all enjoy our cars has made me rethink what i have been doing with my 87 as of lately, which is absolutely nothing.
I have a few key points i need to get to fixing
The Cougar as of today
Ouch
Ouch
Triple ouch
Once i can find another job i MUST start saving to fix this body rot and the dent i put in the overfender. Does any of the aftermarket rust arrester/stopper spray stuff work by the way.
POR-15 is your friend. It *NEVER* comes off though!
I have tried the rust stopper stuff that turns the rust black to no avail.
i dont think rust stopper is actually a fix but more of a band-aid.  i mean it's supposed to slow rusting not stop it, if they're advertising it as a stopper than they're lien SOBS
Nothing will fix rust , but it will stop it from rusting beyond that point by starving it from oxygen and dampness. 2 things that produce rust in iron
Use Eastwood rust encapsulator It beat por-15 in all tests and is cheaper and user friendly.
I've been using it for almost 12- 15 years now. (since it came out)
if you look at the first pics of my cat, you'll see it under the hood from about 10 years ago. the rust didn't creep or go through it.
the entire front of my car in the working stages is all eastwood encapsulator. if I miss any rust with the blaster, It'll get sealed in forever without worry of spreading.
you can also bondo on top of it. Its brushable and UV resistant unlike POR-15
1 quart will do almost the entire under side of a car. 2 quarts would do it twice (2 coats are required for optimal protection)
just remember if the rust has gone through to the inside of the panel it will still rust from the inside.
Those rocker/quarter rust areas tend to rust inside also. (once the seam sealer gives out from rust)
If you need pics of what it looks like on the inside of the quarter panel, let me know i'll post some more.
This way you'll know how to treat the rust without it creeping ever again
check out my link below
Im always happy to help anybody out
Rust
I was in the shop/garage today and decided to snap a pic of the rust creep I was talking about in the last post.
here's a pic thats very common to all our cars
Looks pretty much the same as the pic in the first post.
This one is a little less though.
Here's a pic of the inside of that same panel where the seam comes together.
the rust is starting to spread across the inside of the rocker and the  of the quarter.
Here's a close up
If you repair the exterior of this seam without repairing the inside, the car will keep rusting under any filler, caulk/seam sealer and paint.
I would suggest repairing this also. and at least use a rust encapsulating type of product to keep the air and moisture from spreading it. if nothing else.
I did a quick repair on that area about 10 years ago. I got lazy and didn't strip any of the interior. only to find out, that part of the car has rusted away to nothing.
It only takes a 1/2 hour and a TORX 50 (if I remember corectly) to take that panel off completely
I hope this post helps everybody that has rust in this area
Thank you very much sir, i cant wait to get this car back on the road
Alright!!! Way to go man, gotta say the pics I saw before sure didn't show that stuff! Thing looked pretty  good to me. All that doesn't even look too bad, for these cars! :hick:
Yeah, it does not show the rot or dent well, my dad and i used to when my grandmother was still alive come over to her place (incidentally where we live now) to take care of it because we knew that if we did not she would not. But i did not expect my 75 year old grandmother to wax her car, im just glad my father and i did.
