Topic: brake booster (Read 1257 times) previous topic - next topic
brake booster
looking to see what brake booster i need for my 85 cougar putt'n a 577 in it heard a need a small one any clues? what ideas on the o.d of the difference anyone?? thanks
brake booster
A 5.0 Mustang booster is a lot smaller than a stock thunderbird/cougar one, but I dunno if it'd clear a big block.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
brake booster
Can’t wait to see your car post some pics
Our cars are fox’s so anything done to stangs cane be done to ours.
Good luck
brake booster
thanks one more will the master cylinder work or do i need a "stang" one  i will get some pics up  thanks again
brake booster
Mark, a 1994-95 Mustang 5.0 brake booster (non-Hydroboost years) is skinnier and will work perfectly for what you're doing. Just need to redrill one mounting hole in the firewall. For the m/c, you still have the cast iron one. From 1987-on the m/c was aluminum with the plastic reservoir. It's up to you which one to go with, but as of right now your setup is 2-line (both front, rear) whereas the newer setup is 3-line (left front, right front, rear). It can be replumbed but then you couldn't use a line-lock as easily. You may be better off keeping what you have. If anything you could upgrade to a Crown Vic m/c, which holds more fluid.
brake booster
ok i have the 2 line m/c with a line lock already installed  so that one will work just have drill another mounting hole everything is the same  bolt right up going to get one today thanks MIKE:cougarsmily:
brake booster
will that booster work with tall valve covers?  i have the p-51 heads  with the roller rocker arms mike:cougarsmily:
brake booster
Quote from: onebadcougar;196042
Its going to be tight if it does. manual brake conversion is you friend.
