Topic: Anyone with an 88 EVTM (not 87) (Read 2743 times) previous topic - next topic
I have the 87 evtm but the colors for the premium sound don't match my 88.  Could someone hook me up with the premium sound pages from an 88 specific evtm?
1988 Thunderbird Turbo Coupe
I've got an '88 EVTM, but alas, no (working) scanner...sorry man.
Is there something I can look up for you..?
send me the evtm, ill scan it and cut it to cd,, then mail it back to you.
its ok, this will be quick....  one sec, I'm gonna upload a pic of what I need
Ok, so I need to take the 4 outputs, as highlighted on the left, and get their corresponding colors at the amp (not the back of the radio), as highlighted on the right.  Thanks!
Oh, and thanks for the offer, Scott.  It's awesome you're always willing to go the extra mile to help out fellow t-bird/cougar guys!
hmm...  .  Ok, thanks.  Guess the only other thing I can try is the good ole "cut and listen" process to figure out which wire is input for which channel of the amp...
What do you guys think is more likely;  The amp inputs (low level signal) is on the same plug as the power and ground wires and the powered wires out to the speakers are on the other plug, or vice-versa?
oh man, that's perfect!!  I still don't know about the colors, but since your diagram shows the connector, I can use location to identify my wires...  THANKS!
I wouldn't trust the colors worth a  anyway...just my .02 cents worth...
check out sams site with the wiring diagrams for the radio. There's like fifty or some made up number like that...
Ok, I got close, but upon looking at JeremyT's diagram a bit closer, I realized all the speark INPUTS are labeled except Right Rear...  whats the deal there?!?
