Topic: Pre-bent brake lines ? (Read 2229 times) previous topic - next topic
Does anyone know of a company that makes pre bent brake lines fan 87-88 ?
Highly doubtful that you'll find any.
I find it easier bending them myself.
you can buy a hand bending tool to do it fairly cheap
Classic Tube has them. They're website says it's for an 86, but I'm the one that sent in the lines, and they came off of an 87-88 TC.
Check with the Right Stuff Detailing, rightstuffdetailing.com  I don't know if they have anything yet, but you can send it to them and they will make one for you in steel or SS, and keep the dimentions on file for future orders.  I had them make the Driver's rear line on my 7.5" Mustang, but it looked  close to the 8.8" in the '86 TC I had.
wouldnt brake lines for a mustang rear be the same as the tbird ones? if its a disc 8.8
brake lines
Quote from: daboss351;205188
unless they have changed the mustang rear is 1" narrower than the bird,that 90's and down.
the housings are the same. it's all in axle length that gives you the wider track. if you did need them for disk i would recomend looking at 93 cobras. same as a Tc rear. without the gear.
