Topic: C5 has many issues. (Read 1353 times) previous topic - next topic
C5 has many issues.
I had to replace the C5 in my 86. Suck's, but at least I already had an extra that has been in the garage for about 3yrs. The good news is the new one works,BUT not too well. When I start the car(in P) it jumps foward about 2". After it warms up, it doesn't do it. Also, If I don't come to a complete stop at a stop sign, it wont down shift to low until I step on the gas. Seems like it get's stuck in D, then a sluggish down shift when I accelerate. Last but not least, it will go to low gear if I stop at a red light,but when I take off it has a super sluggish 1-2 shift. The only thing I've done to this tranny is a fluid & filter change. Would a band adjustment maybe take care of this, or am I going tranny shopping?
C5 has many issues.
what trans fluid did you use?
did you check the level after the trans warmed up and in park?
C5 has many issues.
The C5 still has a vacuum modulator on the side. Check your vacuum line for cracks and integrity; if it checks out, replace the modulator. It's around $20 or so, very inexpensive, then go from there. There's a good chance that's all that's wrong with how it's behaving now.
C5 has many issues.
10-4  what Eric said,make sure you hooked the vac back up.
C5 has many issues.
Fluid level is O.K. I used DexIII/Mercon. I forgot to mention in my first post that I did replace the vacuum modulator. I checked the vac. hose yesterday & everything seems to be fine. I've been told that type F will make it shift harder, but it may shorten the life of the tranny. Is this true? I really don't want to change the tranny again unless I'm bolting it up to a V8 & that's not in my budget at the moment.
