Topic: P/S hoses? which is which? (Read 1369 times) previous topic - next topic
My top hose, the one that comes up and then curves back down, blew out on me. The hard line that goes into the fitting is really lose and spewed fluid all over. What would cause this?  i need to know if its the return hose or the pressure hose so i can get it and put it on before i have to work tomorrw.
Since a picture speaks much better than words...there ya go. As far as the leak, most likely worn O-rings on the pressure line or a burst in the line somewhere.
[SIGPIC][/SIGPIC]http://www.fquick.com/slicksport88
88 Sport - 5.0HO, Mass Air, A9L, 73mm C&L meter, BBK CAI, 255 lph pump, 1.7 roller rockers,Professional Products damper, Chuck W motor mounts, BBK shorties & H-pipe, Flowmaster 40 series, 8.8 rear w/3.27's, 93 Cobra M/C, BAER 13in. drilled/slotted rotors front and back, cobra calipers, Russell braided brake lines front & back, C/C plates, 03cobra rims, 255/40/17 Nitto 555's all around
that is what i needed thanks man
