Topic: built 5.0l with or without turbo kit!!! (Read 1323 times) previous topic - next topic
well I'm switching to modular with my mustang and need to sell this engine first!!
engine
new stock block standard bore
probe industries -23cc blower pistons
perfect circle rings
scat 4340 rods
eagle cast steel crank
professional products balancer
dss main girdle
f303 cam
twisted wedge heads(new valves,valve springs,guides,seals,and surface)
cometic head gaskets
funnel web intake
demon 650 blow thru carb
msd distributor, 6al, and blaster coil
ford racing chain and gears
fidanza aluminum flywheel
7qt proform oil pan
arp everything inside
rotating assembly was balanced with flywheel
ect.....
$5000 o.b.o
turbo kit
precision turbo, sc61 with t4 hotside(.96 turbine, .70 comp)
tial wastegate 44mm
tial bov 50mm
ebay stainless hotside
custom downpipe to hook to a standard mustang-t-bird catback
intercooler and all piping, and nice silicone couplers
procharger carb bonnet
ect....
$2000
if you buy both i will drop the price, basically its a turn key setup!!
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
Say it ain't so! :(
BTW, I saw'd your new turbo. That thing is huge, you're a crazy man. :D
yeah i have a 5.4 that im building now, just picked up a tremec 3650 the other day too. but now i need the rest, oh and you should see the turbo with the comp housing on it!!
lol... wow.
you can make that turbo stuff work w EFI right
yes, actualy i was ruuning F.I. on the old engine, you will just need a diffrent intake. if your interested i can take the intake-carb distributor, ect off
I wish I could take all of that off your hands herb! That turbo setup would be awsome with the DOHC 4.6 or my '88 tbird's 308. Would you take payments?:hick: Somebody has to buy this setup, Its scary fast!
~1988 thunderbird~
In hibernation, waiting for spring.
i might take payments, and its starting to look like nobody wants this stuff:mad:
I would post this in the main for sale forum.... you might get some more bites.
sweet i will give it a shot!! thanks
