Topic: t-5 swap (Read 2264 times) previous topic - next topic
t-5 swap
how hard is the swap?i will buy the parts over a period of time.
t-5 swap
its actually realy easy. clutch pedals are more irritating than hard to put in and thats the worst part. rest is a cake walk.
~John~
t-5 swap
I agree it was pretty easy, and it's alot more fun to drive.
t-5 swap
sweet i think i may do it then .im also going to get a tc rear out of a auto xr7.should be 3.73s right?:evilgrin:
t-5 swap
Quote from: superpinto;194298
OK well that makes no sense.  Is it an 87-88 TC rear end that was swapped into an XR-7, or are you trying to assume that an 87-88 XR-7 would have the same rear axle as an 87-88TC?
If it's the first, how are we supposed to know what gears are in the rear end? We don't know what the trans was in the TC donor.
If it's the second, well your supposition is incorrect.
t-5 swap
so the xr7 turbos have a 7.5or an 8.8?are xr7s only turbo?
t-5 swap
http://www.coolcats.net/fox/
that'll give you alot of basic info on fox cougars.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
t-5 swap
Quote from: superpinto;194312
84-86 XR-7's are 2.3 turbos with 7.5 rear axles with 3.45 gears with drum brakes.
The 87-88 XR-7's were 5.0's.  Only the late '88 XR-7's had 8.8's.  Gearing was for a 5.0, so you never saw a 3.73 stock.  All 87-88 XR-7's also have drum brakes 7.5 or 8.8.
You have to specify what year "TC" you're talking about (and what year XR-7 for that matter).  It's not like they were all the same from 83-88.
t-5 swap
are 86-88 tc have an 8.8 rearend or is it 87-88tc?
t-5 swap
Quote from: superpinto;194430
87-88
t-5 swap
thank you to everyone who helped.
t-5 swap
If it matters, the 87/88 TCs are 8.8" and come standard with disc brakes (vented rotors) and a Traction-Lok. The 5-speed 87/88 TCs came with 3.55s and the auto 87/88 TCs came with 3.73s. Prices for these rears are all over the place.
1987 Turbo Coupe - Son's car
1934 Ford - My project car
t-5 swap
thanks that does help i knew that they came with 3.55 or 3.73s but didnt know about the disc brakes also didnt know wether they had oped or trac lock.thanks that helped:D
