Topic: Choke won't release (Read 897 times) previous topic - next topic
Choke won't release
I have an 82 Cougar with a 5.0, and once I get going, it revs real high and I can't get it lower it unless I shut it off for awhile, and is a big problem in winter conditions. I replaced the coolant temperature sensor, but that didn't help. Thanks for any input on this. Happy Holidays!
Choke won't release
Is this a carb or EEC III CFI?
Choke won't release
Thanks for responding. It's an EEC.
Choke won't release
Does it stay on the high step of the fast idle cam?
If so, check for vacuum to the kick down diaphragm.
Check for 7 volts on the wire to the (choke) thermostat when the engine is running.
Choke won't release
Is this what you have?
