Topic: diagram needed on the mn12 platform (Read 1295 times) previous topic - next topic
ive done a serch for some mn12 info and came up with nothing so maybe im hoping someone here has a awnser to my question. I am currently replacing a water pump on my 1990 cougar xr7 3.8SC and it looked like i had to pull the whole alt bracket but i removed the bolts and it still is in place. Im wondering if any one has a manual on how to do the waterpump replacement on one of these engines.  Im new to the SC motors so any help would be appreciated Thanks guys!
Got that fox rash again!
-Resident smartass! :ies:
I can't help much with the SC engine WP replacement, but here's a site that can.  They referred me here because I have a Fox body.
http://forums.tccoa.com/index.php?
Lotsa MN12 experience there, and they do seem to love their SC engines.
:birdsmily:
lemme guess you cant get the drives side accessories off.if this is the case there's a pita bolt down behind the metal brace that goes from the steering pump to the water pump.its hard to see but its there and a real pita to get to.i personally cut a small hole in the plate to access the bolt.i get get you pics if needed just let me know
My 93 was a 3.8 but not SC. I had to buy (you can rent them I think) a tool to pull the power steering pump pulley to get the water pump out. There's another tool to put the pulley back on...
