Topic: MM Strut Brace Install (Read 2364 times) previous topic - next topic
I finally got around to installing my MM STB and I thought I'd post this to try and save anyone from some of the frustrating installation issues that I had. It's really easy to install but there are a few things that can bite you in the ass if you're not prepared. One thing is tools... A dremmel tool saved the day here a couple times; Here's why...
Issue 1: On the passenger side the STB tower mount interefered with the camber plate. So unless you want to remove your camber plate and grind the washer you will have to grind away the corner of the brace bracket and drill a new hole in the brace. The camber plate is in the way of the drill bit so you cant use the inside hole. Here's the pic...
Issue 2: After istalling every thing I noticed the lack of clearance for my oil cap. On my 87 Bird with the worn out stock motor mounts I could get it off... barely. With the poly mounts on this car it was not even close... F@$k! So I had to loosen the STB bolts and pry it up so I could get the cap off. Then I took my trusty dremmel and cut off the bottom of the cap to the first threads. That was enough so now the cap fits fine.
Modified cap:
Here's an overall shot of the whole thing.
Hopefully this thing keeps my strut towers righteous with my coilovers.
The MM STB is a nice unit.
I'm kind of surprised that car never had one to begin with....
hey mine didnt come with the sticker on it. yes it is a very nice peice and fits very well for aftermarket.and it looks good doing it. it is kind of a pain to take the upper intake off with that on though.
Quote from: EricCoolCats;193406
Woweee...that's a tight fit. So you're saying if you have tall valve covers, you're S.O.L. then?
Actually tall valve covers dont have that tall fill tube on them so they'd be fine.
Mine was a pain in the ass to install, mostly at the firewall. Working around all that wiring harness  drove me nuts.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
Quote from: Chuck W;193396
I'm guessing it was because of the Vortech Powercooler.
Quote from: Dogcharmer;193422
Ah-ha!
what year mustang  strut tower brace did you use 79-93 or 94-98 style?
I installed one on the Sport (I don't remember what brand name),and it fit like a glove,and cleared everything with ease.Mine mounts at the strut towers (of course),and at the center of the firewall.
Where did you get the camber plates from ? I desprately need a pair for my 88 sport.
Thanks
1974 Falcon XB-GT Coupe
1988 Thunderbird Sport
1962 Thunderbird convertible
1971 Mustang Mach1 429SCJ
I'm going to guess from the black paint, Max Motorsports.  Not sure, but Chuck W might have some as well.
__________________
Twin '85 TCs
White/ Grey 2-tone
C/C Plates are from MM. And this thread is pretty dang old.
Yea looks cool but.....how does it drive?
