Topic: Chuck's '83 TBird (Read 267056 times) previous topic - next topic
Re: Chuck's '83 TBird
Reply #330
Got a few moments to get a bend in the panhard bar.
Planning on ordering parts this weekend for the adjuster.
Reply #331
While I'm waiting on panhard bar parts to show up, I took care of a couple other details that needed attention.
Got the panhard chassis bracket all fastened down.
Inserted a nut plate behind the upper of the two side mounting bolts (It supposed to line up with an existing quad-shock mount) and ran the lower bolt through the frame. I didn't weld it, as I *may* revisit the chassis brace at some point, and didn't want to mess with cutting things out.
I went to install my non-power lock door plates, only to find that the DS one has gone missing at some point...
New floor mats ordered and on the next round of parts buying in a couple weeks, I'm going to pick up one of THESE to tidy up things under the hood a bit and help aid in airflow management.
Reply #332
That radiator piece is cool!  Thank Chuck.
Are you going to rivet it in?
Mike
Reply #333
Not sure yet. I may do some small riv-nuts, as I'd rather be able to easily get it out of there if I need to more easily access anything with the IC or oil cooler.
Reply #334
I agreed, would be nice to easily take off.  Let me know what you go with, thanks.
Mike
Reply #335
The panhard parts showed up today.
Hoping to test fit things and get this together by the end of the weekend. Floor mats are supposed to arrive tomorrow.
Reply #336
How is that insert being attached to the bar?  I see a chamfer, welded?  Will you be running a tap through it afterward?
1988 Thunderbird TC, 5spd
'21 F150 Powerboost
'17 Husqvarna TX300
Reply #337
So is the EVTM the inspiration for the green color?
One of 1,246 built
Reply #338
It'll be welded. I had no issues with the panhard bar I modded on my 240 using these parts. Same with the new upper links I built for this car with the weld-in bungs.
I have the car down, suspension loaded. I'm going to mock up the original bar to see what length the car wants for everything to be centered. Then I'll cut off the section to allow for me to insert the new parts to allow for some adjustment around that point.
Reply #339
Heh.
Nope, just wanted something different.
Reply #340
Heh.
I can respect that.
It's why we own what we do and not another cookie cutter Mustang.  :smile:
One of 1,246 built
Reply #341
Looking good. Can't wait to see it move under its own power again.
Reply #342
Well, I started to make some progress today.
Got the rear centered under the car and mocked up what I needed the nominal length of the panhard bar to be.
Then I cut the LH threaded end off and cut it to fit the new adjuster parts in for the correct length.
Then I grabbed the other weld bung from the package to weld it in. After it cooled a bit, I was test-fitting the jackscrew and it wouldn't thread in. So, I gave it a dirty look and grabbed the 5/8-18 bolt that was sitting on the bench...and that threaded in.
 :beatyoass:
I was sent a mis-made part. See that scribe line in the weld bung? That means LH threaded, as BOTH of them in the package should've been.  This one was RH threaded.
So, instead of having the car done and on the ground today, I'm having to wait for a LH rod end to make this all work now.  :bs:
Reply #343
Finally got a couple moments to get the panhard installed this evening.
I may need to pop it back out quick and clearance the PS side of things. It's not super happy with the female rod end in there.
It is however ready to come down off the stands.
This weekend I'll be buying that fill piece for the front of the engine bay and getting the remaining bits to reconnect the heater.
I disconnected it waaaaay back when not because the core was leaking, but because I'd deleted the coolant passage out of the intake, and needed to figure out different coolant tubes, and never got around to it. Getting around to it now.
Reply #344
I spent a little more time making myself feel better about the panhard bar. I needed to do a little clearancing of the rod end spacers to get things to be happier in the bracket.
Then we got to this point.
