Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1538090 times) previous topic - next topic
Reply #930
I have an old wire feed welder but even on the lower setting and moving fast it still burns through sheet metal. :mad:
Im trying to find someone around me with a TIG welder.
88 Sport, custom white 140 mph gauge, 11 in brake upgrade, stock mustang headers, bassani x-pipe, cherry bomb vortec lers, HO conversion
Reply #931
Quote from: Kitz Kat;257359
I've been messin with a cheap 110v  lincoln wire  feeder,
I'm impressed what it can do.
I've got a 110v lincoln. works great with the gas mix
Reply #932
On my lower rear passenger side 1/4 panel,it had a crease in from the wheelwell to the lower corner of the car near the bumper.I got a "new" panel,cut off the unnecessary metal,made a "skin" out of it,and used body panel adhesive to attach it to the car over the damaged area..It's solid,and is never coming off.The body lines are just right,and it didn't stick out past the bumper cover.No-one that has seen the car up close can tell I did that work,even after I tell them.GOOD stuff.
Reply #933
I Need A Fix!! Help me out brother.
Reply #934
daminic.. since your going with a black paint job.. if it does, infact, come out like glass over that drivers side quarter panel.. MUCH RESPECT.  body work + black paint = TRICKY.
Reply #935
Quote from: ~AC;257691
I have seen the 1/4's on and felt them, and I was impressed with no distortions, I do believe he will make it look fine.
Reply #936
Yea, the quarters came out  almost perfectly straight
here's a shot with the light on it.
and when the filling is done this will fill the imperfections when blocked flat. this stuff can add an 1/8" of fill in a couple coats if needed.
Reply #937
hey hey hey
3  There will be absolutely no nudity tolerated in any image, whether it is hosted on your server or ours. Our web host has a strict no-nudes policy and we honour it. Scantily-clad women in your avatars are included in the ban if they are offensive
get some paint on that quick:D
Reply #938
i also touched the drivers side 1/4. and  i also can voutch for its straightness. and i have a 88 TC model at home that is flat black with black interior and ironicly is almost what jerry is doing to his.
Got that fox rash again!
-Resident smartass! :ies:
Reply #939
Here's a better view. the distortion is minimal along the weld, as you can see here.
Reply #940
Project "Evolution Rrrrrrevolution".Nice welding my friend.I have no doubt that the Cougar will be almost as cool my Sport.LOL.LOL.
Reply #941
ah i see.. i was worried when i saw the picture where the 1/4 is down to metal completely.  you can see the weld line, but instead of distortion like i thought i saw, it looks good enough that you wont use much filler.  you defiantly have my respect!!
Reply #942
I did some blasting today, after I removed the wiring
Here's the drivers side
I guess I also need to fix this
It's not as bad as I figured. I'll be welding new metal for extra support, and smoothing everything out.
Today's big question......... Where do I disconnect the lower line for the air conditioning that goes through the firewall?
Reply #943
Quote from: baxo;257990
It would be the same distance for eu to the peace bridge. It's 30 mind to my house from where he is.
LOL
Is the question sealed inside a mayonnaise jar?
Reply #944
Haha freaking iPhone and its auto complete.
