Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1491231 times) previous topic - next topic
Reply #2790
Just spent the last ~2 hours skimming through this thread.
This has to be the most informative build thread i've seen on here, its given me so many things to consider when i'm looking for a tbird locally.
seriously impressed!
83 Thunderbird Heritage - Right Hand Drive
95 Falcon GLi
Reply #2791
Quote from: daminc;357570
Yes I got the stainless P headers around Christmas time
Quote from: daminc;357575
They are pretty... wonder what color they'll turn after I run it...I'm hoping for blue myself... lol
If you didn't get the Jet-Hot coated ones (I didn't) then they will turn dark gray and have a bit of surface rust, just like mine.
Reply #2792
Quote from: EFFalcon;357803
thanks, my favorite part of doing this whole project, is when it got painted..... looks so much better in person when compared to the pics...
Reply #2793
Quote from: thunderjet302;357804
yea, I'm prepared for that already too. that seems to be the way they go... either blue, or they look burnt.
Reply #2794
Jerry, you're going to have A/C aren't you? I have the Sport's working great now, but I have one problem....I've gone A/C delete so long, I forget it works and get pretty warm in the car before I realize "Hey !!! I have A/C !!!". What parts are you still needing (other than injectors...I'm working on that).
Reply #2795
Yes. AC is a must in a black car...I will know in a week or 2 if I need anything.. possibly an intake spacer is all I might need. I haven't put anything together, so I'm not sure what I'm missing yet.. Just collecting what I can to make it go faster when I get to it
Reply #2796
well, after the py start on Saturday. Today went a lot smoother except for the arthritis, due to the weather being cold and damp...
Random pics as I'm working on the brakes, and the rear brake lines.
found my upper brake line..
thinking I need to paint the brackets for the brakes....but what color?
Reply #2797
I realized that the door jambs are my favorite part of my rebuild....I don't know why... but they are pretty crisp looking.
Reply #2798
Beautiful........and the jambs really do look crispy. I love looking at your update pics, It helps me stay motivated to get the Sport back into her fighting shape.
Reply #2799
as an update from the other thread on Friday...I did get the calipers moving after some soaking, found the bolts, and upper brake line. Probably finishing the hard brake line, and moving on to the trans crossmember later today..
Reply #2800
The crossmember will be easy stuff. I'm going to go out and do some mods to my throttle body and play with that to eliminate the whistling. Then, may bump the timing up to 14 where it was.
Reply #2801
hopefully the bolts won't give me a problem.
Reply #2802
For the crossmember? If they are bad, let me know and I'll grab you some.
Reply #2803
Dude,that is sick.  Really sick.  I wish I had 1/10th your skill at bodywork.  I've kinda lost motivation to work on mine.  It's been 95 degrees, IN THE GARAGE!  Lookin at stuff like this though, makes we wanna get started back.
Reply #2804
lol....My garage is air conditioned too.... Had to rub that in..lol
 Thanks, it just takes some research, practice and a lot of patience to get it done.
Vinnie, I don't have any bolts, so I'll be heading to Fastenall to get something to bolt it in.. Had to cut the old ones because of rust. If I can't find anything, I'll let you know. but I should find something I can use over there.  What grade bolts are in there anyway?
