Topic: Project Evolution *** Project Complete **** Wednesday July 9, 2014 (Read 1530547 times) previous topic - next topic
Reply #1965
I have thought about a full digi dash,but have no idea how to do it.
Reply #1966
here's the wiring for it. you also need a digi sender. I also believe through testing, that you can wire the regular sender backwards, and it will read in the correct direction instead of backwards, there's a thread about that.
http://www.coolcats.net/tech/general/8588digital.html
Reply #1967
I really hate the tach on my full digi-dash.  You can't set idle by it.  Whenever I stomp on it, my brain takes too long searching the cluster to find out I've just buried into the red.  I have a sport cluster I am waiting to install.
Also, periodically my gas gauge will blink E.  But only on rare occasions.
The sounds it makes are nice .
Reply #1968
more of the same stuff. sanding and priming...
This should be the last of the flattening. After this(again, because I was paranoid it wasn''t flat enough), I will be priming a couple more coats, and on to the wet sanding. The last step before the finish paint. Well, it still needs to be sealed with epoxy again, before the paint,, but it's considered part of the finish painting. (I'm rambling, just look at the pics. lol)
here we are again, another coat of primer
Can't forget the little stuff
guide coat. I don't think I showed this step in the priming stage yet.
after a few minutes of using a 16" block. It's insanely flat
More sanding this week, then priming for the last time. :D
Reply #1969
Won't be long!
Reply #1970
Update.. Trunk lid and hood are now sanded. sides tomorrow.
Reply #1971
I think you should sand it back down to the metal, Just to be sure you got it straight!
Reply #1972
I haven't been on much in the past 2 weeks, computer virus. It's looking good! Almost time to see some color!
Reply #1973
Quote from: Kitz Kat;310633
I agree completely.No need in taking any chances after all you've put in to it.
Reply #1974
I get the feeling he didn't like that comment. It was a joke, Your doing a great job.
Reply #1975
Quote from: Kitz Kat;310940
I actually didn't see it until now. I would do it again if I had to. :D
Reply #1976
progress as of friday.
Reply #1977
I'll probably start sanding mine next month. It's gunna hurt to put the sander to it at first, but then I will be dedicated. I was hoping to have it done last year.
Reply #1978
it's always tough to start. I felt the same way when I started cutting entire sections off the car.  There's no turning back from that.
Reply #1979
Not when you cut them off there's not.
