Topic: Which springs to use? (Read 2219 times) previous topic - next topic
Which springs would be good to drop the front of the Sport about 1-1 1/2 inches?I've seen the Stang lowering springs,but didn't know how well they would work on our cars as far as the actual drop would be on my car ('88 Sport).Something I want to do as soon as spring gets here.That comes early here in Oklahoma.
I've heard or rather, read about some fellas using the newer Cobra springs, at the expense of a harsher ride.
Most likely the 96-98 springs, as the IRS springs would be different.
The reqar I'm not worried about,and I really don't want a really harsh ride.I understand that I can't have a Lincoln feel to it,but an inch to an inch and a half lower with a decent ride would be nice.
Try picking up some 5.0 Mustang springs that are supposed to lower them about an inch or so. I have used BBK coils up front in mine and they brought the front down nicely. I don't know how much exactly but it wasn't anything excessive, I never got it aligned afterward and I'm not getting any weird wear on my tires (well except for wearing out the outside edges ;))
Oh yeah, the ride mostly sucks if you're on any kind of rough road, but then it wasn't any better with the stock springs. I think it's the PRC struts more than anything. Car feels good and tight and handles awesome, but you feel every bump.
Garrett H.
'87 Thunderbird Turbo Coupe
Engine, wheels, tires, etc!
Exhaust sound clip
Another clip
I already feel most bumps with the low profile tires I'm using.I just need it about an inch or inch and a half lower in the front.I didn't know if Stock Mustang springs were any different than the Sports stock front springs.
Everything is a compromise. Bullitt/Mach 1 Springs... seem to be a good "middle of the road" spring set in my experience. The rears will prolly require spacers or adjustable RLCAs...
Thanks.The rear of my car is low enough when I take the shock spacers off.They lift the car about 1 3/4 to 2 inches.I need a good spring to lower the front about an inch to an inch and a half.How much do the Mach 1 or Bullitt springs usually run for?
Used, you can get a whole set for around $100. Check eBay and corral... it's been awhile since I bought anything Fox related so I'm not too keen on the current market.
I think there are some places that still sell them new. Not sure if they split them up though.
Thanks a lot.I'll check the Corral first.
I'm sure you've read my posts here, but my ride height is 26.5" from ground to bottom of fender lip with worn 225/60/15's (25.2" diameter) using Mach 1 springs. I got them used for $100.
I've got the 17x9 Cobra R wheels,and they don't need to hit the fender lips.I'd like to trade them for a pair of 17x8's.I may just buy the 17x8 wheels and call it good.They hit my struts without spacers.It's always something.No big deal.I can work that out easy.
