Topic: No Overdrive (Read 1774 times) previous topic - next topic
No Overdrive
I have lost overdrive, it'll shift but if i touch the throttle the RPM just go up and the car stays at the speed its going.  I was thinking about a lightly built one from B&M or accurate.  I kinda want a manual valve body to go with my hammer shifter.  Anyone got some good recommendations?
2004 Impala
No Overdrive
Manual VB will get old fast, but then again, I am pretty lazy when it comes to that stuff.  Does anyone in your area do performance rebuilds?  They are not hard to do.
Matt :tg:
No Overdrive
how do u use a manual valvebody on a car with no true second gear selection? sorry for the hijack, i just dont see how that idea works.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
No Overdrive
Quote from: grutinator;192765
Most of them modify the valve body so 1=1, D=2, and OD=3. Over drive is usually activated electronically via a switch (like the 4R70W where you can turn OD on and off with a switch).
No Overdrive
A guy on TCCOA gave me a receipe for a mean tranny using parts from an AODE and a 4R70W but i dont know if i want to do that because i would either have to find and buy a used tranny then the parts then pay someone to build it, or pull mine out then give it to someone to build.  I want to try to rebuild an auto but not when im under the gun ya know.
2004 Impala
No Overdrive
Quote from: capitlj;192689
Classic disconnected TV cable symptom... If it's not the cable its a OD servo or band problem...
No Overdrive
Cable is connected and not broken, so I need a tranny DOH
2004 Impala
