Topic: flywheel nuts (Read 2196 times) previous topic - next topic
flywheel nuts
i guess this is the best place to put this thread. we need a 'stupid question' category cus this fits in perfectly there.
how do you remove the flexplate/torque coverter bolts on an engine with no top end? everytime i try to put any torque on them it just turns the whole engine over.
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
flywheel nuts
You could try holding the front crank bolt ,but it might just break it loose.
flywheel nuts
jam the flywheel with something
flywheel nuts
remove starter
use a socket / extention / breaker bar on the crank bolt and put it in a bind againt the frame/near by bracket or floor.
line up nut and remove
rotate crank to new nut
repeat.
btw, its much easier if your spark plugs are out.
flywheel nuts
i would hope the plugs are out if theres no top end!
flywheel nuts
Quote from: daboss351;192608
Tis what I did. Worked beautifully.
Get a friend to stick the flat end of a crow bar or tire iron in between the teeth on the flywheel and have at it.
flywheel nuts
Quote from: 5.0willgo;192636
where the hell am i soppose to get a friend? lol. thanks guys, i thought about that, but i was the only one home at the time. i was hoping there was a one person method. i'll call someone up and try again tomorow using these tips. thanks.
-keith
flywheel nuts
I got them loose on the engine in the '80 by myself.  I just wedged something against the flexplate teeth and had at it.
flywheel nuts
if its in a stand, a big block of wood worked for me wedged it against the flywheel and stand and pounded it under. got them out no problem after that!
flywheel nuts
if you have air use an air ratchet and swivel socket
louie  :birdsmily:
My famous last words:
flywheel nuts
They sell a flywheel tool.
flywheel nuts
Torch!!
lol
No.. Just kidding!!
You already have the right suggestion.. jam the flywheel at the teeth
flywheel nuts
Quote from: Tbird232ci;192997
they make a tool for everything, but when i have pry bars already, and they do the same job...im going with prybar
Quote from: Jim_Miller;193000
No.. Just kidding!!
yea, i'll try to do that when i can. i get sick at the worst times. hopefully i'll get better quick and that stupid engine will finally be out.
