Topic: Well, slowly but surely (up and running) (Read 8707 times) previous topic - next topic
Quote from: 87thunderbirdBlackJack;192652
yay, interior is almost done
You might want to cut a hole in the carpet ;)
Quote from: grutinator;192667
so whats the medal from?
My girlfriend is a swimmer, and she placed 1st in regionals.
Quote from: thunderjet302;192685
uh, HURRR:hick:  Never thought of that.
Just wondering but are you beefing up the 5.0 at the same time? A stronger motor + the T5 would be fun :burnout:
its beefy, but the summer will make it beefier, if not then then ill haveums me a winter project :D
The AOD sucked, so... it'll be a different beast with the t5
Quote from: 87thunderbirdBlackJack;192741
I forget but what have you done to the 5.0 in it? I know you rebuilt it but I forgot what you did to upgrade it :D
not worried about the motor thats in it :D
you should be worried about the block on the stand :D
Im planing a buildup of a 331 with a lunati cam PORTED E7's (I hogged the f*ck out of these)
Nothing major.... for the first $3000 saved up :D
Someone say boost?
Quote from: 87thunderbirdBlackJack;192806
Someone say boost?
Ah should be fun. Just don't blow up the trans ;)
The more I see this done,the more I think I need to do a 5 speed conversion.Now,I need to check under the cushions on the couch for spare change.I'll take donations.
By the way,I'm getting a little jealous here.I need a new garage to work in.You're doing what I need to be doing.
everything has been easy. only thing that gave me some trouble was the carpet, thats the part when you need 2 people...
Oh and vinnie... its a 3 1/2 bay garage with heat propane and Kerosine
lucky... My car would be done if i had a garage. Its buried under snow right now...
money is my only hinderance. kerosine is 3.99 a gallon
!!! I guess so! With a garage that big must suck to heat. My grandfather has a nice old gas heater running off his house set up, heats up NICE. Wish I could get my car there!
just a little bit
 you! I would kill for a 5 speed.
When ya gonna paint 'er?
after the n/a motor gets built
