Topic: S-197 Shift s? (Read 2866 times) previous topic - next topic
S-197 Shift s?
Any way to make these fit our cars?  I scored a new '05 Mustang GT  for $10 but it's too big for my shifter (Steeda Tri-Ax).  Any ideas?  '86 TC.
S-197 Shift s?
Make your self a bushing. Those universal after market ones use hard plastic tubing pieces of different thicknesses to make there  work on your shifter. What I say to get you some metal tubing and thread the inside to screw on your shifter. Then thread the outside to let the  screw on to it.You will most likely have to make it the right thickness.  Then you might be able to make and sell those bushings most of the After market stang shizniters come with Stock treaded handles. So you can understand how many people this could work for. I even think the 80's camaros with borg warner T-5 have the same threaded shifter. Never know you night be able to find a Heli coil that would make it work.
S-197 Shift s?
jb weld and re-tap
S-197 Shift s?
I had the same problem with a shift  from a '95 Camaro Z-28.
The best suggestion I got was to use a heli-coil to compromise for the larger threads.
I never got around to it, though. I used a nylon bushing insert with some epoxy and tapped the T5 threads into it.
It worked perfectly until I ripped off the  during a spirited 1-2 shift. I think it's still in the back seat.
S-197 Shift s?
Ok, thanks guys.  I'll let you know what I can come up with, if anything.
S-197 Shift s?
3M duramix just spray some WD40 on the threads fill the hole with duramix make sure its pointing the right direction and in minutes it will fit perfectly and thread off easily.
2004 Impala
S-197 Shift s?
That sounds like the best idea yet... Which Duramix product would I use...  The metal bonding adhesive?
S-197 Shift s?
Weird.., my s197  threaded right on my stock t5 shifter.:confused:
95 Ranger Splash 2.3
88 Tbird Sport :ies::ies:
S-197 Shift s?
That is weird...  The thread pitch for the '05-'08 s is 12 x 1.25.  Anyone know what ours is?
S-197 Shift s?
Quote from: cougarman;192207
Ajsbird on here has a s197 shifter  in his also
S-197 Shift s?
did you do the whole righty tighty, lefty loosey thing? if u have to...hold out your hands, the one that looks like an "L" with your pointer and thumb is your LEFT hand. turn it the other way.
haha, sorry:D
1988 Thunderbird sport
2004 Ford F150 Lariat
2008  Chevrolet Cobalt Sport
1988 Thunderbird LX - sold
S-197 Shift s?
dual threaded pipe fitting?
S-197 Shift s?
Filled her up with JB Weld today... I'll snap some pics tomorrow when I get it on the car.  Thanks everyone!
S-197 Shift s?
That sounds nice but how are you gonna tap it so that the top is pointing in the right direction?
S-197 Shift s?
I'll just have to keep test fitting it as I go along...  That's the downside but I think I can make it work.  If that doesn't work or I go too far, I'll stick a nut on the shifter that the  can tighten down on.
