Topic: Hazard Relay (Read 1119 times) previous topic - next topic
Hazard Relay
Need help in identifying the hazard and turn signal flasher(s) for a 1995 T-Bird.  Both the hazards and turn signals are not working
I have searched the web for the flasher and came up with a Motorcraft Multi purpose relay # DY864 Ford # F8PJ-14N135-AA.
The local parts store says there are two flashers and that they are the same.  They only thing they had was the standard two pin flasher in a metal can.  The picture on the web shows a plastic unit.
I looked in Chilton for where the flasher(s) is located.  It says "The flasher unit can be found under the dash panel attached to a bracket on the right side of the steering column opening reinforcement."  I have looked in this area and cannot find a flasher that I found on the web.
What I did find was a module with the following Ford # F4SB 14A672 AA.
My question does anyone know if this is the flasher for both the hazard and signals?
Thank you for your help.
Hazard Relay
Softtouch,
Thank you for the information on the thread.  It has been a help.
