Topic: 347 found on Craigslist, Spokane WA (Read 984 times) previous topic - next topic
Sounds like a lot for the money, even if it is a lot of money.
TED
Ballanced and blueprinted , 1988 5.0 roller block, Forged 347 Stroker Crank, Forged Probe rods, Forged Probe 10:1 pistons cut for Trick Flow Twisted Wedge heads, Trick Flow stud girdle, Trick Flow Twisted Wedge Heads, Trick Flow pushrods, Omega Aluminum Roller Rockers, Ford Motorsport Hydraulic Roller lifters, Trick Flow Stage 2 Cam made for Twisted Wedge heads, BBK shorty headders, All ARP hardware throughout, Edlebrock high flow water pump, Griffin Aluminum radiator, Summit low profile electric fan, comp cams double roller timing chain, Fluidamper harmonic ballancer, Fidanza aluminum flywheel, King Cobra Clutch, McCloud hydraulic throwout bearing, Freshly rebuilt World Class T-5, Accel Gen 7+ DFI Pro Ram system with Dual Sync Distributor and Wideband O2 kit, MSD Digital 6 Plus ignition, This motor runs awesome! No leaks. Very Clean. New engine with dyno time. If you purchase this engine I will tune the fuel and ignition maps for free on our chasis dyno. If you have any questions don't hesitate to ask.-Bryce brycel333@msn.com              509-998-5810        Best Offer. PTR Injection 6463 N. Perry Spokane, WA 99207 Will consider splitting up the transmission and motor. http://www.ptrsds.com
