Topic: Stereo on/no sound (Read 2164 times) previous topic - next topic
Stereo on/no sound
First, this is not in my car, but a newer Subaru Legacy - I think 2005?
Anyways, supposedly one speaker at a time quit working after replacing the factory stereo and speakers with a Pioneer DEH-P880PRS and some Infinity Reference 6.5" speakers in the doors (not sure the model) - Two of the factory speakers were blown. I went in there today to take a look into this and removed every crimp connector to solder/heatshrink every connection from the stereo to the speakers. Everything tests out fine at the headunit with 11.8-12v coming in from the red and yellow wires, and something pretty low on the ground loop. From the harness to the speakers, they range from 3.6-4.0 ohms resistance with no continuity to ground. From the stereo being turned to max, there remains ZERO volts AC coming from the speaker channels.
I pulled the stereo and hooked it up inside to one of the speakers from the car and a power supply. Everything tests out fine and all 4 channels work with 3-4v on the speaker lines at full volume (just to get a reading so I know what to look for when in the car). Hook back up in car, no output from speaker wires again. Unhooked all speakers at the doors and the circuit on each set of speaker wires stays open ("1" on the multimeter).
From what I'm gathering, one of these factory wire runs are messed up somewhere, causing the headunit to go into protection. Is the next step to solve this removing speaker wire pins from the connector until I find the one thats causing the problem? Ideas?
btw, I got snowed and rained on hard today trying to solve this. I'd rather have an order of probability I can use to test this thing tomorrow so I don't have to freeze my ass off again.
1988 Thunderbird Sport
Stereo on/no sound
I've had 2 or 3 pioneer head units loose sound.  It's a common problem.  Stereo is on but no sound.  Check for a "click" when you turn the unit on.  If you hear the click then the relay is working for the output module.  If not then it needs a new one.
Or it can be bad solder joints in the power supply area. The joints heat and cool over the years and crack.
:pics-stfu:
 Project Thread with pics
Stereo on/no sound
It works fine when we brought the deck inside and hooked it up to a power supply without all the car wiring in between anywhere. The deck is fine, just not when installed in that car.
Stereo on/no sound
Sounds like a bad connection then.  Sorry I can't help more.
:pics-stfu:
