Topic: Custom Aluminum Driveshaft (Read 1350 times) previous topic - next topic
I have a Custom Aluminum Driveshaft for my T-Bird.. it is almost brand new also have the Steeda spacer that is needed depending on what trans you have.. comes with all the bolts
$250.00 + Shipping FIRM
$50.00 Spacer
This thing is only a few months old and I am switching to a TH 400 and need a longer Driveshaft now...
NEEDS GOOD HOME
Ron 734-776-5987
PLEASE CALL
Does this fit a stock style 87 5.0L with AOD????.
If so is there anything i have to change over or modify??
Where was the driveshaft made,any pics,3" 4"????
no pics yet, it was made by a guy my chassis builder uses. it is a 3.5" and it has a yoke on it now that should work with the AOD and C4 I also have a Steeda spacer that I had to use the spacer when I put my TKO in the car.. the shaft is only about 6 months old.It also has all 1330 U Joints in it
Please call me
Ron 734-776-5987
Really interested ron but i would like to see some pics of it.
Also december is a killer bad month for me for buying car parts,got 3 birthdays and christmas.
Should be getting some cash for christmas,if you still have it in january we can definetley do up a deal of some sort.
Might have some cash in 2 or 3 weeks does that fit a 1987-1988 T-Bird with AOD? Shipping for both to 79110 don't think i need the spacer but still be nice to have if i change out my AOD.
Shipping for both to 11735?
Broke now but i will give you a call if i get the money for it anytime soon.
Without the spacer would it fit a 5.0 AOD T-Bird? right now i can't off more than like $190 which i am not even 100% sure if i have that right now.
Does the shaft fit the 8.8 axle and will I need the spacer to run a Tremec 3550 II trans?
Blueprinted 306, Thumper ported Canfield 195's, TLSR Camshaft, custom motor mounts, Parker funnelweb, Pro Systems Carburetor, Tremec 3550 II, 4.30 gears, Moser Axles, Team Z custom suspension with upper relocation brackets and anti roll bar.  At the track I run M/T 26/10's on Weld Star rims.
