Topic: 9 mpg in city (Read 2129 times) previous topic - next topic
9 mpg in city
yea i posted this in another topic a few days ago, but now ill make this a priority.
i can easily attain 30+ mpg on the highway no problem, but in the city its a consistant 9-10.  i dont drive hard on her, and last year i replaced all gaskets/hoses/plugs/wires/filter.  i use 93 octane (as i heard anything less the MSD wont run correctly) and my trans was rebuilt 2 years ago.  the engine temp indicator stays perfectly over the N (whatever the heck that temp is  :dunno:  ).  could it be my exhaust?  im runnin 2 1/4 h-pipe to flowmaster 40's, then 2in from lers back, and have the cats removed.  and performance seems adequate.
any help would be appreciated.
Re: 9 mpg in city
Your exhaust is not all out nuts so I would think this is not the cause of your problem.  Heck I had a 2.25 system with glasspacks on my old 3.8 and she didn't suffer with city gas mileage.  Your good highway mileage would indicate your car has a good tune up and is running properly.  Is there a possibility that your car is holding on to first gear too long? Maybe not even using second at all?
Re: 9 mpg in city
i do have that cable that adjustst your shifting points set a little higher than usual, maybe about an 1/8th of an inch.  cuz in the "stock" position, when i have her WOT, sumntimes shes shifts to early.  so i set that cable a little tighter so she shifts at around 15-18 mph into second gear while cruising, and shifts into 3rd gear around 35-40.
those are just what i think i remember the shifts points are. i havent driven the car sence june :(
doest mean i cant work on it tho  :)
Re: 9 mpg in city
The fuel economy in these thing sucks especially if its stock, i mean if its pushing more HP you expect it to be thirsty. right
2004 Impala
Re: 9 mpg in city
look for a vacum leak. I had one , but I never bothered with it because the car would idle perfectally. As a matter of fact, my auto teacher said that he never saw a ford(chebby guy, cool as hell though) run so smooth. I got about 7 mpg in the city and about 25 highway. I have been known to punch it when people try to pass me though. After my car died,  I decided to tackle the vacum leak. It ended up being the line to the map sensor :brick:. also, I had jet black exaust, and the car always smelled like gas after I floored it.
