Topic: Full digital cluster questions (Read 6105 times) previous topic - next topic
Some of the senders are unique to the full digi-cluster.
I know the fuel and oil are, not so sure about the coolant sender.
You'll have a hard time finding the fuel sender, they're ed uncommon.
I couldn't find the sender anywhere.
I'd say just be safe, get all three: oil, temp, and fuel.
I also *think* that the fuel pump/float *may* be unique to the full digi-cluster, someone will know for sure.
In case you didn't find it, HERE is some info you may need.
I'm rather certain I've done the W2 mod on a full digital cluster. When I bought my parts TC it had a full digital cluster out of an '87 Sport in the trunk. I did the W2 mod and sold it on eBay.
Also, I believe the fuel sender for full digital is still available new (the buttstuffogue ones aren't). There's a thread about it here
I'll take a closer look at it today. I guess I need to grab a new sending unit as well. I noticed there was a statement about 85 tanks being unique, is this true and would I be better off to use a 86 tank?
Quote from: Thunder Chicken;189728
Yeah, I forgot about that. My issue was that they are typically rusted solid and you can't get new clamp-rings for either the Gauge sender or Fuel Pump sender. Dunno - I just know I hate these gas tanks. I have had leaking at the top of the tank and I can't get all the parts needed to install a new tank so I can never fill my tank. I'd love to get a new tank if all the associated hardware was available :mad:
Quote from: Drewstang;189677
Will this drop right in to my car?
NO
  or will I need to ad modules or oter stuff?
Yes
I gave this topic about an hour of time looking at the cut sheets from both the evtm and the shop manual comparing the Base and Electronic clusters.  You will be very surprised how many wires are placed either as a different color or in a different pin location on either the A or B connector.
There are three clusters out there.
Conventional - 83/84,(possible 82's), buttstuffog
Base- 85>88, buttstuffog,digital,bulb warning illumination
Electronic 87>88 (refered to as a "star wars cluster" i think.,  digital and bulb illumination
I will assume you are currently a Base model with only an electronic speedo.  If so, this swap might be very interesting and a challenge even for the wiring geeks out there.
I can provide you with the three critical shop manual pages which match the information i will provide in the EVTM as well.  Just be warned now, this isnt plug and play like you asked.  Secondly, this does not include any special sensor configurations.  I am just learning about this myself because i now own a 20th.
take this as a first warning, im not sure why you havent been warned yet.
I would bet the farm that the speedo mod would work on the electronic cluster like thunderchicken already said.
I wont say it cant be done, dont under estimate and you can surprise yourself.
Yes, I have base right now and I would like to install the fully digital (star wars, I always called it Knight Rider cluster.) I would like to see the EVTM because one day I'm sure that I will get on a mission to make this work. Right now my main focus is the SEFI swap and SN95 Mustang brake swap. Wiring does not scare me if I have the right EVTM. I've swapped out 4 dash harnesses in Mustangs and made repairs and modifications while in the process. If I need to take the dash out and do the same to make this work, then I'll put it off for when I change the heater core.
I can guarantee that the speedo mod works on a full digital anyway.
ok, tomorrow i will scan in the shop manual base and electronic cluster wiring as well as the evtm pages so you can lay them out and finagle around with it when the time comes.
