Topic: fan/blower location (Read 8376 times) previous topic - next topic
fan/blower location
Dumb question but my heat ant blowing out and I’m getting cold. Its dark right now and I don’t remember where it’s located. I thought it was located in the fire wall but I’m wrong.
88 bird
fan/blower location
I thought it was all the way up under the dash above the glove box. but i could be wrong. ive never had to get to mine.
fan/blower location
By the heater box.....  Take the glove compartment out.
http://www.foxtbirdcougarforums.com/showthread.php?t=6701
http://www.foxtbirdcougarforums.com/showthread.php?p=70666#post70666
http://www.foxtbirdcougarforums.com/showthread.php?t=10344&highlight=blower+motor
fan/blower location
it's not blocked?
fan/blower location
yes.  the flappers sometimes break off the cable
fan/blower location
did we go through all the tests in the post before this one?
fan/blower location
This is true.  Mine sticks in the cold weather at times causing my ATC to go nuts.  When it does it it's usually open most of the way.  I've got to go under there one of these days and see what the deal is....
fan/blower location
is yours cable or hydraulic?
Ive always had problems with all my vehicles with heat in one way or another. i think ive seen it all by now
fan/blower location
which farmingdale do you live in
fan/blower location
The ATC uses an actuator with an arm on it to move the door.  The actuator is good.  I can hear it strain when the door gets hung up.  If I cycle the system on and off a few times when it happens it will free it up.
The same one Innes does, on Long Island;)
fan/blower location
mabe rust forms on the wire arm or hinges in the damp seasons or during air cond. season
fan/blower location
thanks for the help guys looks of things it ant easy and i never done it before.
theres no-way i'm pulling it w/a hunch its bad ill test it first w/a volt-ohm meter.
fan/blower location
so there's no fan movement at all at any speed?
fan/blower location
I've got relatives in Brentwood I haven't seen in years. Maybe one day I'll be in the area.
