Topic: 2.3 Turbo Mods (Read 7638 times) previous topic - next topic
2.3 Turbo Mods
I have an '86 Cougar XR7 2.3 Turbo. I've been reading and searching for mods, and i'm pretty sure that i want to get a full 3" Stinger exhaust, and a K&N Filter for the VAM.
My question is about a gillis boost valve?? i know that it controls the boost, but how do i install it/use it, and where can i get it. i am also looking at getting a blow off valve but it looks like i will need a special pipe to run from the turbo to the throttle body is that right?? And if so where can i get it, i Looked on Forced4.com but their descriptions didn't help
i'm not looking for junk parts, but budget is key. Thanks for your time and any help would be greatly appreciated
2.3 Turbo Mods
40bob.co sells the gillis and all other 2.3l parts youll need.
Gillis comes with instructions,turn the boost upto 22psi install a k&n and have fun.
NO need for a blow off unless you must have that woosh sound.
2.3 Turbo Mods
Quote from: dominator;189416
Or unless you really enjoy damaging your turbo bearings.
2.3 Turbo Mods
????? The turbo has an internal wastegate why do you need a blowoff, and it wouldn't be the bearing that got damaged by not having one it would be the impeller blades.
2.3 Turbo Mods
I shelled my ihi by running 18psi with no blow off, every time I let off it boosted back into the turbo yanking the empeller forward. It eventualy wore enough to pull the impeller into the compresor housing and made a realy cool noise. Kind of like a cut off wheel on metal. It then dumped copious amounts of oil through the compresor and made my car smoke like a big rig!:D  still boosted 15pis after that. Now I have a t-3 and a blow off, and run 20psi:burnout:  no problems
2.3 Turbo Mods
Quote from: dominator;189444
The stress on the impeller blades from building full boost and closing the throttle plate (shifting) is what stresses the bearings.
That's the whole point of a bypass or blow-off valve - to vent that sudden surge of pressure.
The wastegate simply limits the total amount of boost the turbo can make. When a certain pressure is met after the turbo, the actuator opens the wastegate flapper and diverts the exhaust away from the turbine.
Sure, when you close the throttle under heavy boost, that actuator will certainly go full-bore into opening the wastegate, but there is no other connection between the two. It is not the same thing as venting off the sudden surge of pressure between the compressor and the throttle body.
With that being said, I've read that a bypass valve is better for our cars than a blow-off valve. The bypass will allow the purged air to re-enter the intake, thus maintaining the correct air/fuel ratio after the VAM.
2.3 Turbo Mods
lol  don't waste your time ...
i've bin down this road meny times with them lol
i've tried to explan how a wastegate works and a carton of cigarettes later it still would'nt sink in.. i even made a bet to have someone disconect the shaft on the wastegate just to see how much boost the turbo would make under a full throttle load..  i had no takers on the bet..
2.3 Turbo Mods
You should also try to work in an Intercooler if your going go above stock boost.
1985 Thunderbird TC
2.3l .03 over,Ported and polished Head and E6 Manifold, LA3, T3/T4 Hybrid Turbo, Stinger FMIC, Forge BOV, Full 3" Exhaust, Essy Timing Gears & UDP's, BBK 255lph Fuel Pump, Kirban AFPR, Kirban Short Shifter, K&N Cone, Forced4 VC Vent Kit, PA Performance 3g Alternator, Energy Suspension Bushings throughout, CHE LCA's, SFC's [/LEFT]
2.3 Turbo Mods
Quote from: Blown306Cougar;189448
On a .030 over rebuilt 2.3 with a .63 T3 it takes 5500 RPM to hit 5 psi! :hick:
2.3 Turbo Mods
wow thanks guys im gunna look into the gillis thing
i have to get the K&N filter b/c i dont think that tractor air cleaner is good on power lol
a BOV is  probobly going to be one of the first mods that i get more for cheap insurance on the turbo as apposed to the power i'll will get
now do i have to run the pressurized air from the BOV back into the intake or can i just let it expell atmospherically??? and What kind of pipe do i need to run one on my car???
2.3 Turbo Mods
if you want to put the air back into the intake, you want a bypass valve, a BPV
2.3 Turbo Mods
I would NOT attempt 22 psi without an intercooler. I think 15 psi would be my max there.
2.3 Turbo Mods
The wastegate has nothing to do with the shockwave of pressurized air that travels back down the intake tract towards the turbo when the throttle is closed while under boost (i.e. shifting).  Wastegates are  on the turbine (exhaust side) and the BPV/BOV's are on the compressor(intake) side.
If you disconnect the shaft on the wastegate and assuming the WG flapper is not stuck, the turbo will build no boost as it will all be vented.  Disconnect the signal hose from the compressor to the WGA, then you will have uncontrolled boost.
BOV/BPV's are used to vent the pressurized air in the intake tract as mentioned above, not to control the boost level.  In addition to possibly damaging the turbo, running longer IC pipes w/o one can result in "trailer hitching" at part-throttle/cruise situations as that air  has no place to go.
For stock 2.3T systems, or those with "mass air" metering, BPV's usually work the best as they keep the metered air in the system.  Cars running a speed density set-up can make better use of the BOV's as there is not "metering" of the incoming air and the fuel mixture/demands are figured by the MAP sensor.
2.3 Turbo Mods
:rolleyes:
Long time Turboford freak...
84 SVO
88 TC
87 XR4Ti
2.3 Turbo Mods
thanks chuckw....now to sound like a noob....
ihave stock '86 set up, is that mass air meter or speed density. I though it waas too old to be MAF.
And wtf does the VAM do, i know where it is but i dont know what it does
thanks for the help guys!
